BC4-1810 – Homework, Yukino Hatake
Forum Archive BC4-1810 – Homework, Yukino Hatake
Viewing 15 posts - 76 through 90 (of 180 total)
  • #42755
    silentheart00
      @yukinoh1989 First, what’s the operating system?
      #42756
      Aaron Rudderham
        @yukinoh1989 If you simply want to check your GPU and CPU, then load up Blender 2.8, go to Edit > User Preferences > System and then under CUDA it should say. I do believe it only shows Nvidia GPUs but I could be wrong, worth a shot at least.
        #42757
        Grady Pruitt
          @yukinoh1989 the camera angle on your Eevee is just a little higher than the one on the turtle, so makes the comparison a little harder. but that said… I think overall, you did a great job matching. I think the light coming from our right (the subject’s left) is a bit stronger in the reference. It’s either stronger and/or a little closer., which also makes the shadows (particularly of the parts to that side) stronger in the reference than on the Eeveee. Great effort!
          Nice work on the car.
          #42758
          Grady Pruitt
            On the files.. I think I found the storage for the “installed” ones… If you’re using Windows, check your user’s AppData folder (If I remember, before 10 You could find this easily in the same directory as the Documents… which it is in 10, too, but you have to go through your root directory->Users->(username).  In the AppData, look in the Roaming folder for Blender Foundation->Blender->2.80->datafiles->studiolights->world. If you delete it from there, I think it will “uninstall”.
            #42759
            Jake Korosi
              @yukinoh1989  Showing it in different lighting conditions is a neat idea!
              Looks perfect to me.
              #42760
              yukino hatake
                @silentheart00 , @thecabbagedetective and @gradyp thanx for helping me out
                first of i found the GPU is a GeForce GT 640
                and i have and intel core i7 CPU
                system is windows 10 home
                and i have 12 RAM installed
                the processor is 64bit
                just a question where can i find the root directory ? or where is that located
                #42761
                smurfmier1985
                  @yukinoh1989 That’s almost the same as my laptop. I got windows 10 pro 64 bit, nvidea 650M video card, intel processor i7 and only 8gb RAM. Blender and Eevee work fine for me. I wonder what’s wrong with yours, maybe it’s really broken.. ☹️
                  #42762
                  yukino hatake
                    @smurfmier1985 is there a way to find that out?
                    #42763
                    smurfmier1985
                      @yukinoh1989 Probably, but I’m not a hardware person so I couldn’t tell you how.. when I get weird stuff like you get I go to a computer repair guy.
                      #42764
                      yukino hatake
                        @smurfmier1985 guess I gonna have to wait then. Can’t yet go sadly
                        I also uploaded the good renders both of car and lightning match. So I guess for now I still gonna be able to work like that.  But I better don’t render anymore above 500 samples
                        #42765
                        Grady Pruitt
                          @yukinoh1989 The root directory (on Windows) is usually the C:\ drive
                          #42766
                          Grady Pruitt
                            @yukinoh1989 I rarely ever saw the need to go over 1000K because you never saw much increase in quality versus the time it took to render, but since denoising, I usually use 500 when using Cycles.
                            #42767
                            Zsolt Cseh
                              @yukinoh1989 Yukino your lighting match exercise is almost perfect for me. Also good to see your own model from the previous class again
                              #42768
                              yukino hatake
                                @csehz thank you so much I am glad to hear that 😀
                                #42769
                                  @yukinoh1989 Good work this week! I like your unique sports car color scheme. Fits well with the vehicle style. And overall your S&L looks nice. The ground bump map is believable too. It’s an A from me on this half of the homework.
                                  Your light match is among my favorites. Very close to the source which is a great choice: Perfect for showcasing models. Also an A from me 👍
                                • The topic ‘BC4-1810 – Homework, Yukino Hatake’ is closed to new replies.
