BC4-1810 – Homework, Yukino Hatake
Forum Archive BC4-1810 – Homework, Yukino Hatake
Viewing 15 posts - 31 through 45 (of 180 total)
  • #42710
    yukino hatake
      @silentheart00 I sure will keep doing my best with what I have 🙂
      #42711
      Zsolt Cseh
        @yukinoh1989 Yukino I like to check your thread regularly, because I know that you ask a lot of and so I am also getting valuable information in questions 🙂
        Very nice to see how you learn step by step
        #42712
        yukino hatake
          @csehz thank you so much I am happy to hear that. Somehow this time I also wandered of to other topics to ask a lot of info. I sure did learned a lot again. And I love that so much since it gives a good feeling :).
          #42713
          Christina McKay
            @smurfmier1985 Thanks for the tipps! Your recommendation to the Shader forger will help me very much. The node system and me aren’t friends yet 🙂
            #42714
            Christina McKay
              yukinoh1989
              Yukino, wow. I like the truck and your room renderings so much.
              You’re improving incredibly fast. If I learn things at least half as fast as you do, I’ll be happy.
              #42715
              yukino hatake
                @chrismckay thank you so much. It really makes me happy to hear that. And I indeed am learning at a really good speed. But that is of course than to @theluthier and the help of you guys the community. I am almost constantly in blender the past 2 months and week and keep learning so I am really happy to see ethe results from it
                #42716
                yukino hatake
                  I do have a question. Especially on the blue you see a lot of scratches. Is there a way to increase the offset of each scratch or reduce them? Let me know if I must post a screenshot of the node tree I have so far
                  #42717
                  yukino hatake
                    pfew i think i can call the toy truck done 🙂 .
                    at first i was thinking of adding stickers or someting else but i guess i am happy with how it looks now . and damn those node tree’s they grow really fast when you try to add someting 😮
                    this is the final result i have (trough i wish i knew how to give depth to the producenal scratches but i guess its still visible ).
                    first you have a somehow plastic material (exept for the iron of the wheels that is indeed brushed metal)
                    then i added scratches some dirt and dust (trough with the dirt on the yellow somehow it doesnt apprear everywhere :s i wonder what is causing that . if anyone knows pls tell me .
                    it should look like a toy that is pretty old
                    i have 2 versions but not sure what is best
                    this one has dust but set to facing
                    this one has set the dust to fresnel
                    #42718
                    yukino hatake
                      found out how to get the dust better trough its still not as clear . i also added dust to the floor let me kno< <hat you think is best so far
                      #42719
                      silentheart00
                        @yukinoh1989 I think your latest truck looks the best on the dust.  Nice touch adding it to the floor.
                        #42720
                        yukino hatake
                          @silentheart00 thank you. I also will be sharing my file with a better render and upload the start post
                          #42721
                          yukino hatake
                            @silentheart00
                            newest render and file if someone want to take a look at it
                            Toy truck finished
                            #42722
                            smurfmier1985
                              @yukinoh1989 you made a lot of progress, the truck looks great! 😄
                              #42723
                              yukino hatake
                                @smurfmier1985 Thank you so much miranda. i sure did my best . trough i still wonder about a few things that i cant figure out .
                                maybe some can help me with these questions.
                                1: on the front wheel you see 4 small lightblue dots does anyone know what is causing this ? is it the light ? someting of the node setup ?
                                2:somehow you see the dust but i like the effect better on the floor then on the toy. not sure eighter here why that is diffrent 🙁
                                3: is it possible to use the node wrangler in 2.8 ? i know kent used it but somehow its not working in my 2.8 file 🙁 so its hard to see some effects without the black and white value
                                4: is it possible to change the offset of the scratches ? so they are further placed from each other ?
                                5: as you see for the dirt somehow at the side of the toy it isnt appearing while in front it does appear. can this be fixed ?
                                6:if for example i want to use a scratch motive like this but want to add depth to them so its more like real scratches how could this be done
                                7:another one of the scratches. is it possible to set a certain collor for the scratches ? now they are darker then the base but what if i want to use that effect of the setup but more want to let it look like a kid painted with collors on the truck how can you set collors for that ?
                                sorry for the bunch of questions . but i tought that its better to add them here again . sometimes i didnt knew anymore where i asked a certain question so it can be hard to find back xD
                                #42724
                                silentheart00
                                  @yukinoh1989 I suggest watching the Week 2 videos as it’ll answer some of your questions.  But the updated version looks good.  I’ll get back to you on some of those questions.
                                • The topic ‘BC4-1810 – Homework, Yukino Hatake’ is closed to new replies.
