2.8 Hurdles and Roadblocks
Forum Archive 2.8 Hurdles and Roadblocks
Viewing 15 posts - 181 through 195 (of 255 total)
  • #47704
    Jonathan Lampel
      @frikkr Hmm, I’m not sure right off the top of my head. Can you share the file?
      From what I understand from reading back on this post , render layers have now changed to the icons that are available in the outliner/collections panel
      Sort of, render layer functionality has been split between collections and view layers. Since your collections seem to be in order, you could try investigating your view layers.
      #47705
      Matthew Fricker
        @jlampel Thanks!
        What do you mean by view layers? I’m still getting to grips with 2.8 and working through the transitioning to 2.8 course. I understand collections now , but I’m not sure what you mean by “view layers”
        #47706
        Jonathan Lampel
          Matthew Fricker
            Thanks Jonathan 🙂
            #47708
            Matthew Fricker
              Is anybody else only seeing two pages of this topic now? There used to be about 13 pages but now I can only see 2.
              The screenshot below shows what I see at the bottom of the first page :
              #47709
              smurfmier1985
                @frikkr Yeah they updated the forum, all replies are embedded now into the original post..
                #47710
                Matthew Fricker
                  Ahh thanks , I see that now.
                  If I could suggest a further update – it would be good to have the pages buttons at the top of the page too so that you dont have to scroll right down to the bottom of the first page every time you want to read the last post on a topic that is more than one page long 🙂
                  #47711
                  Matthew Fricker
                    @jlampel that worked thanks! , the composite output node had been disconnected – presumably in the transition to Blender 2.8
                    Fixed now though , big thanks.
                    #47712
                    smurfmier1985
                      Or a ‘jump to last page’ button! Have been requesting that for a while now 😇
                      But @frikkr suggestion is just as good and probably easier to implement!!
                      #47713
                      smurfmier1985
                        @wesburke I do wish all the replies weren’t so hidden.. that’s the downside of embedding, you can’t see them right away it’s easy to miss things.. 🙁
                        #47714
                        smurfmier1985
                          Awesome! They did the ‘page buttons at the top’ and ‘unhiding replies’ thing!! 😃🙌🏻
                          #47715
                          Matthew Fricker
                            much better 🙂
                            #47716
                            Cookie Dough
                              Simply beautiful!
                              #47717
                              Markus Berg
                                And now that messages gets embedded, there probably needs to be some kind of indicator to which messages are new. If there are 10 pages, and someone replies to something on page 8, most people will probably never see it, unless they painstakingly go through each page checking the date. Unless there already is an indicator and I’ve missed it.
                                #47718
                                smurfmier1985
                                  @wesburke see excellent point by @thebergh above
                                • The topic ‘2.8 Hurdles and Roadblocks’ is closed to new replies.
