BC1-1808 Homework, Yukino Hatake
Forum Archive BC1-1808 Homework, Yukino Hatake
Viewing 15 posts - 106 through 120 (of 348 total)
  • #39265
    yukino hatake
      @thecabbagedetective
      Does 2.79 also have collection maps where we can order them?
      #39266
      yukino hatake
        @golden-kitty
        Hey dont worry you did helped too good . i think 2.8 indeed is still bugged in several ways but hope to see it fixed soon
        #39267
        smurfmier1985
          @yukinoh1989 Sadly no.. that’s a new feature they added in 2.8. They do have some sort of layer system but I haven’t used it much. They are the square boxes at the bottom of the viewport.
          #39268
          yukino hatake
            Is it possible to get this triangle shape to a perfect straigt line in x axis ?
            #39269
            yukino hatake
              @smurfmier1985
              Thanx to let me know . i guess its better if i stay trying in 2.8 then since i believe otherwise it will be getting messy in blender xD
              gonna have to duplicate a lot of the fence’s
              #39270
              Aaron Rudderham
                @yukinoh1989 Sort of, it has layers which function similarly but aren’t as deep as collections.
                I presume you want it to turn from a triangle to a square? Simply select all of the verts you want to edit (as you have done), hit S to scale, then hit X the lock it to that axis, and then hit 0.
                #39271
                yukino hatake
                  wow thanx a lot that is indeed what i needed.
                  i also looked up some more modeling technicks and wonder about bevel . can you also increase it like the amount with loop cut ?
                  #39272
                  Aaron Rudderham
                    @yukinoh1989 Yep! Just use your mouse scroll wheel.
                    #39273
                    silentheart00
                      Just wanted to drop in and say good progress (and also keep my place)!
                      #39274
                      yukino hatake
                        Question when i take grid fill . i get a message select 2 edge loops ? with the first type of pillar it worked fine but now it wont work .
                        Does anyone know what the problem could be ?
                        #39275
                        yukino hatake
                          Another question i have . i used the mirror modifier and array but now i have somehow verticies too much like in 1 edge there are 2 ?
                          How can i fix this ?
                          edit : found it . i had to take remove doubles it seems . (if anyone still could help with the problem about the grid fill i would love to hear what is causing that problem)
                          #39276
                          Aaron Rudderham
                            @yukinoh1989 Mind giving me your .blend file so I can have a look? Not entirely sure what you mean.
                            #39277
                            yukino hatake
                              hey sure . i manage to extruded the verticies to fix the problem since grid fill wasnt working . but now it seems the loop cut took is somehow not working :s it works in the length(x axis) but not good on the y axis width . I tryed to add more edge loops by using loop cut but had to use knife tool so far (that is why i needed to know how to align the verticies . maybe i do someting wrong so pls let me know .
                              right now i would love to add more loops in the upper part of the house called “gelijksvloer”.
                              this is the blend file
                              .blend file
                              also some update on what i have (feels like this takes forever been busy studying and modeling the whole day already and yet didnt even manage to get any further)
                              #39278
                              Aaron Rudderham
                                @yukinoh1989 Alrighty, cheers for that, I’ll do my best just have a gander today and try and locate the problem.
                                #39279
                                yukino hatake
                                  Thank you so much . i checked the course where they explained the loop cut tool several times but without succes. and working with knife tool is taking more time. i really hope you could figure out the problem.
                                • The topic ‘BC1-1808 Homework, Yukino Hatake’ is closed to new replies.
