Backhoe Contribution – duerer – Wheels / Rear Axle
Forum Archive Backhoe Contribution – duerer – Wheels / Rear Axle
Viewing 15 posts - 151 through 165 (of 225 total)
  • #58170
    Adrian Bellworthy
      I will fix that gap between your axle and the drive shaft, I left it until you finished that part as I was unsure of position and size until now.
      Not sure the gap between the tyres and the fenders are as big as it looks in that image, a little deceiving in x-ray mode.
      #58171
      Ingmar Franz
        @adrian2301 Thank you for the adjustment and thank for your awesome work on this backhoe as well as to the whole team making this possible 😀! I already looks great 👍!  I often spend minutes just orbiting around our model🦅! We have run a marathon and are only a few meters away from the finish🏆.
        #58172
        Ingmar Franz
          Just a test where the hydraulic lines could run along:
          @adrian2301 Do you have any reference for this?
          #58173
          Ingmar Franz
            I’ve just seen that the wheel hubs and rims at the front axle need to be aligned with the front axle’s rotation axis:
            #58174
              @duerer Make sure we are using the correct wheels!
              @theluthier said he’d use my wheels and then the front wheels are perfectly aligned…
              It’s important to all be on the same page here, before changing anything!
              #58175
              Ingmar Franz
                I totally agree, @spikeyxxx ! Looking forward to the completion of our DOG 😀 !
                #58176
                  @duerer Apologies for the delay – I just added @spikeyxxx’s wheels to the master assembly file so we’re all reference the same for final 👌
                  #58177
                  Ingmar Franz
                    So, the highlighted part in the image below together with the bolts has to be moved towards the axle center in order to fit to the chassis and the axle ends have to be moved further outwards in order to fit to the wheels:
                    But this would distort the proportions of the rear axle’s outer parts as can be seen in the direct comparison with Kent’s reference image. Does anybody have an idea on how to solve this?
                    #58178
                    Adrian Bellworthy
                      I think you are in a bit of a dilemma @duerer , leave the bolts for now and concentrate on the wheel alignment. I will have another look at the chassis and see what I can do.
                      #58179
                      Adrian Bellworthy
                        @duerer , I gave the chassis a couple of knocks with a sledge hammer, you can now tighten your bolts. 👍
                        #58180
                        Ingmar Franz
                          Thank you, @adrian2301 , for your chassis modifications👍! This makes the axle-to-wheels-alignment a lot easier for me😀.
                          #58181
                          Ingmar Franz
                            This is what happens to the rear axle when trying to adjust it to the front axle’s rims (semitransparent green):
                            And the hub case would need some stretching, too:
                            File is here.
                            #58182
                            Ingmar Franz
                              So, with further stretching, I could adjust the rear axle to the tires:
                              It’s now out of proportions but I would accept it as believable.
                              #58183
                              Shawn Blanch
                                Yeah I think it is definitely passable still. I had to do a decent major change to my assembly as well in order to angle the main loader arms to fit proportions.
                                Yours is a sacrifice worth making and I think it will be acceptable.
                                #58184
                                Ingmar Franz
                                  Thanks @blanchsb for your approval 😀. I’ve done some further adjustments:
                                  And with the chassis:
                                  Some minor adjustments are still necessary here:
                                  File will be uploaded to Google Drive probably tomorrow.
                                • The topic ‘Backhoe Contribution – duerer – Wheels / Rear Axle’ is closed to new replies.
