Paul Caggegi
Forum Replies Created
Viewing 15 posts - 1 through 15 (of 252 total)
  • in reply to: subdivide fill and merge #99125
    Paul Caggegi
      Check preferences for where ALT might be enabled to emulate middle-mouse functions. If Emulate 3-button mouse is enabled, Alt will create a different function.
      Another thing that might be enabled which would mess with this default hotkey is under Keymap in preferences – Alt Tool Access. By default, that should be switched off, and can create an issue with the hotkey demonstrated.
      in reply to: Cloud and stroke direction problems #99071
      Paul Caggegi
        Hi Shaun! I would highly recommend you download Blender version 5.01 since this issue has been FINALLY fixed!!
        in reply to: Extrude, Inset, Knife #99010
        Paul Caggegi
          Usually hitting Enter when you’re done with what you want cut will commit the operation.
          in reply to: Importing Brushes / Creating .asset files? #93758
          Paul Caggegi
            Yes, categories work best with brushes saved as assets, since the category is saved in the .cat file. So if you like to organize assets and know where things are, this is the way to go! I’ve generally found categories saved to the current file on a duplicated brush sometimes don’t save. I should test to make 100% sure, but I think it has something to do with where the catalogue/category information gets stored.
            Paul Caggegi
              Yes that is correct: I edited them side by side to demonstrate how each look like in their edited state.
              in reply to: Volume? #98649
              Paul Caggegi
                Hi Gorillamilk! I’ll take a look at the recordings when I get the chance. Thanks for the heads-up! I’ll try and pinpoint where in the production pipeline I can fix this issue. Sorry about that!
                in reply to: Importing Brushes / Creating .asset files? #93755
                Paul Caggegi
                  I will be discussing simple methods of saving brushes directly to your file (my current preferred way) as opposed to Assets. The pros of saving it to the file is that all the settings and changes that you make as you go are saved within the file. You can share this file and the brushes will be preserved. You can also filter them in any asset shelf like so:
                  While any metadata editing is greyed out, it is not necessary because all changes are saved within the file itself.
                  Currently this is my preferred “no fuss” way of working, but should you wish to create a brush pack, then saving the brush as an asset is how you do it. These files are self-contained .blend files – name.asset.blend – and you can edit these like other assets. Where you file these away is completely up to you, just know that a .cat file will be generated and updated wherever your library is created. Often when things go wrong, this file is not updated or is corrupted, and you can either go into the text file and manually edit (if you know what you are doing) or simply delete the files and get Blender to generate a new one.
                  Both methods are not entirely interchangable, but they have their uses. It is really cool that you can work in a simplified, no-fuss way, or be an asset afficionado and catalogue everything.
                  in reply to: pivot snapping and proportional editing #98612
                  Paul Caggegi
                    You can also hit ESC and this will cancel the operation.
                    in reply to: Cannot find jpg file x52sTI.jpg for floor #98584
                    Paul Caggegi
                      I did not have the rights to bundle that image in with the file, so was using it for the purposes of demonstration. Using your own texture is the way to go.
                      in reply to: Remarkable Course & Teacher #98390
                      Paul Caggegi
                        WHO DID THIS
                        in reply to: NO TRANSFORM FILL TOOL #97680
                        Paul Caggegi
                          Yes this is correct. The gradient tool is actually MUCH easier, and works over multiple selections. Here’s a quick demo:
                          I have here some shapes, all with a solid fill texture.
                          I have created a texture fill called Dot. Under Surface, I have disable stroke, enabled Fill, and imported a texture which is a single filled circle with an alpha channel, and set the blend to 1.000
                          In edit mode, I will select just the circle…
                          and assign it the dot texture:
                          The circle will now have the dot texture applied – not very well, but applied.
                          With the circle still selected, pick this tool – the gradient tool (yes, I am hoping they give it a better name, because it can be also used in this way)
                          Now, click and drag anywhere on the canvas, and you will be able to control the scale and rotation of this texture.
                          THAT’S NOT ALL! You can also assign this texture to a different selection – or multiple selections if you wish the texture to work over more than one.
                          Both shapes selected:
                          What is still missing however, is precision. you won’t be able to enter exact rotation or scale anywhere. 🙁 Hope this helps?
                          in reply to: Guide tool is missing #97565
                          Paul Caggegi
                            Yup. Still waiting for it to come back. They promised it will return at some stage, but no word as to when, just that it will be bigger and badder. I really miss it.
                            Paul Caggegi
                              Yes this is correct! It “snaps” to the closest geometry – a vertex or face – not wraps around to fit snugly. That is a different function altogether and can be done with modifiers.
                              Paul Caggegi
                                Ah ok, I recreated this. I have thge cylinder here, and I have selected my Add tool, and switched it to Add Cone.
                                I place my cursor over the face where I want the cone to snap.
                                If you click and drag, it will scale non-uniformly from a corner point…
                                but if you hold down Alt, it will scale from the center
                                If you hold down Alt and Shift, it will scale from the center AND scale uniformly
                                Click to commit the area of the base, and then move your mouse outwards to give the cone height
                                Hope this helps?
                                Paul Caggegi
                                  You ,ight be interested to know I am currently putting together a course specifically about this! Title is yet to be decided on, but it will focus on the fundamentals of drawing for absolute beginners! I will be using Grease Pencil as the tool, but the techniques discussed are transferrable and universal.
