polybook yukino1989
Forum Archive polybook yukino1989
Viewing 15 posts - 151 through 165 (of 227 total)
  • #38649
    silentheart00
      @yukinoh1989 Yeah, that area.
      #38650
      yukino hatake
        not much yet but this is what i have so far .
        i do think i need to speed up the beach ball a bit and perhaps tighten the spacing of bowling ball at start a bit too.
        #38651
        yukino hatake
          WIP version 2
          if you guys notice any mistakes let me know.
          the next part will be most difficult since a lot of balls gonna interact with the beach ball .
          #38652
          smurfmier1985
            @yukinoh1989 hi Yukino, I’m happy to provide feedback but it’s kinda hard to say something useful at such an unfinished state… once you have all your interactions & reactions in place and finished all the movements, feel free to tag me. I’ll make some time to gives some critiques then.
            Happy animating! 😊
            #38653
            yukino hatake
              @smurfmier1985 thanks a lot i sure will . gonna try to first fix the beach ball since i keyframed the root there too instead of the body.
              #38654
              smurfmier1985
                @yukinoh1989 what I would do:
                Turn off auto keying and keying set. Copy all key frames from the root. Paste them on the body. Delete all key frames from the root. Turn auto keying and keying set back on.
                Pretty quick fix 🙂
                #38655
                yukino hatake
                  @smurfmier1985
                  somehow i have trouble with copy . i know how to duplicate but how do you copy keys ? should readed this sooner xD but well ya i just redid the little part 🙂
                  #38656
                  smurfmier1985
                    @yukinoh1989 well.. it works the same as in most software programs. CTRL+C to copy, CTRL+V to paste.
                    I’m off to bed now, I will give feedback on this tomorrow after the livestream 😊👍🏻
                    #38657
                    yukino hatake
                      @smurfmier1985 gonna try it out tomorrow. I look forward to the feedback :). Have a good night.
                      #38658
                      smurfmier1985
                        @yukinoh1989
                        Hi Yukino, back from seeing Pepper create yellow snow :-p
                        First wanna say good job so far! You’ve made a really difficult version of this exercise with so many balls, and there’s a lot of good stuff in there. Just a bit of polishing before you add rotations, but the base is strong.
                        Here are my notes for you,
                        First drop / rolling on platforms:
                        All balls seem to have pretty even spacing when dropping and rolling (as far as I can judge without motion paths, which would be a spaghetti mess in this exercise so I’m glad you didn’t turn them on lol). Remember, when it drops it’s like the vanilla bounce, tight spacing on top and the spacing gaps getting bigger and bigger, with a pretty big spacing gap before it hits the ground. With the rolling balls it should also get bigger as it starts to roll faster down the ramp, only the build up goes a lot slower then when it falls, more subtle.
                        Basketball:
                        – When it falls on the second ramp the bounces can be a bit bigger, it’s quite a bouncy ball.
                        – It starts rolling fast too soon after that, make it start a bit slower and build up speed.
                        – Bounces on the ground look good 🙂
                        Bowling ball:
                        – The drop on the secon platform, the height is good. I do think it goes to far to the right (up the platform). Try reducing that traveling space by 50%
                        – When it hits the beach ball, it’s good you change the drection but I think in this case it’s too much. The bowling bal is really heavy, while the beach ball is super light. Changing the direction empasized the interaction with the beah ball, but in this case it should be a really subtle small change of direction.
                        – Bouncing on the ground looks good 🙂
                        Soccer Ball:
                        – Bounces after first drop look good 🙂
                        – After that is shoots of like a rocket! That’s pretty cool but more for a cartoon animation 😉 It now looks like it speeds up on the horzintal part. But it should be more like this: when it rolls of the platform it should build up speed thanks to gravity, when it goes horizontal it slowly loses momentum, as wel as going up a platform. The distance is short here so it won’t lose much momentum.
                        – After the rocket shot all the bouncing and rolling back looks good 🙂
                        Blue Ball:
                        – It feels like it sticking on the ground instead of bouncing (the second small bounce is the culprit here). Then it shoots of at the same maximum speed. Apply all the same principles here I mentioned before.
                        – The stop at the end is too sudden. When it hits the wall with so much force it should roll back a lot further.
                        Beach Ball:
                        – This one is the hardest, and it does need a bit of love, but it’s a good start 🙂
                        – When a ball hits it, make it go fast at the start when it shoots of in another direction, but then let wind resistance take over and slow it down (like a bouncing ball when it goes up, start with big spacing gaps and then make it tighter)
                        – It feels like the beach ball is waiting for a frame or two, hanging still in space, before the basket ball hit it. Make sure it feels like it keeps moving.
                        – The arc on the drop from the platform (after all the hits) could be a bit nicer. It feels a bit like it goes too flat to the ground.
                        – The bounces between the bowling ball and baskett ball (when it floats to the ground) feel a bit wonky. Check the graph editor there, you probably have to smooth out the curves.
                        So, my advice for you. Since you are pretty far in the bootcamp let’s step up your game and train your eyes 🙂
                        – Watch your video over and over and compare with my notes. See if you can spot what I’ve seen. Go frame by frame and also play it at full speed, switch between those. Train those eyes.
                        – Then get a good nights rest since it’s already late :-p
                        – Tomorow (or whenever you have planned to work on it again), polish the translations. Rest your eyes for at least an hour. Then watch it the same way as before with my notes and see if everything is fixed. If not, repeat as often as necessary. Also, there will probably be new issues when you fix something (that’s pretty common). Try to spot those and fix them too 🙂
                        – After that do the same with adding rotations, but this time, after a rest, try to make your own notes. Pick it apart. Train your eye to see more yourself. Adjust & review, over and over again, until your happy.
                        – Then just submit it and let Wayne be the final judge 😉 because you can never see everything with your own work, that’s a fact, we animators need feedback. But you can train yourself to see a lot more and get better at that every time!
                        I will say it again, pretty good job so far! Keep it up and happy animating 😀
                        #38659
                        yukino hatake
                          @smurfmier1985 thank you so much Miranda for the amazing feedback. Tomorrow I go start looking to see if I see the wrong spots. It surely was not easy. But I wanted to challange myself here before I go onto the character ball. I am also happy to hear I did a good job on this.
                          #38660
                          yukino hatake
                            still struggeling with the complex multi obstacle drop.
                            the hardest part is the beach ball. not only for the movement but also rotation. did anyone noticed its not 100% round ?
                            at first i didnt knew but i do know now its damn hard since i need to adjust so much .
                            #38661
                            yukino hatake
                              still am struggling with the beach ball but i fixed already some other balls.
                              there probably still are flaws and issue’s i cannot see anymore since i stared a full week at this animations i am trying to do xD .
                              but i guess the balls i have so far looks not too bad. (next time i do gonna thing where to place what ball (should placed the blue ball on the left and soccer on the right. since the blue one dont need animation xD but i think it worked out not too badly)
                              have fun watching it
                              next upload will be when the beach ball is completed.
                              #38662
                              yukino hatake
                                After a long time i finished my complex obstacle multiball drop exercise
                                i will be taking a small break and first try making a character design since i have someting in mind. of course i might always change minds :p
                                #38663
                                yukino hatake
                                  trying to sculpt a character. (female)i am not going for a realistic result more a anime , disney , kidsmovie result 🙂 working on the face first then ill move onto the body .
                                  if you guys spot someting off be sure to tell me . still working onto it but if someting aint right be sure to tell me 🙂 .
                                  i think the nose is ok . the eyes kinda creeps me out xD but maybe i need to put in a placeholder of the eyeball and finish the eyes so they wont look so weird xD the mouth also is a struggle but i hope it will turn out well. (still need to do the ears xD .
                                • The topic ‘polybook yukino1989’ is closed to new replies.
