COLLAB2021 – Los Habaneros – House Interior Team
Forum Archive COLLAB2021 – Los Habaneros – House Interior Team
Viewing 15 posts - 196 through 210 (of 436 total)
  • #63966
    Keith
      Cool! These plans really help to visualise the layout. I suppose the waterwheel mechanism could stretch in to multiple floors if we wanted – I guess it depends how complex it should be.
      #63967
      Keith
        Here’s a couple of kettles so Melvin can at least have a brew when he moves in!
        #63968
          I’m guessing all the crazy ideas will settle into yes’s or no’s the day of the stream by Kent. Because you know, if you let us just riff this house would already have turbines that lift it off the ground.
          #63969
            Very nice Keith. You can tell by the distortion of the lens that it’s to scale.
            #63970
              Melvin is going to open soon enough.
              I think we might need to start planning a layout. Things are beginning to take shape to keep it blindly.
              @createtaiwan I don’t know why put the chandelier has some weird streaks coming out of it. Maybe splines left unhidden or something like that. Also maybe it could be bigger, feels a bit small in comparison to the whole room.
              #63971
              Dave Hudson
                I will look into the streak issue today (and make it about 180% bigger).
                #63972
                Cookie Dough
                  There is still a lot to do, but I have the basic colors down. I also realized I’m missing an appendage. Woops!
                  #63973
                  Cookie Dough
                    I decided I’m just going to be an artist and not give it the fins it rightfully deserves.
                    I don’t know how to do the eye and I’m taking suggestions for what to put on the plaque.
                    #63974
                    Shawn Blanch
                      That is looking great. Maybe a critique is to play with the chain link size a little? I’m thinking almost 150% size increase may be in order? Just thinking out loud.
                      Stylized look to the chains may look cool IMHO.
                      #63975
                      Shawn Blanch
                        I’m thinking why stop with the mad scientist room from the water wheel? What if there is a rope pully that goes under or above the house inside the ceiling or similar and Melvin uses mechanisms all over the home?
                        I’m thinking Wallace and Gromit style
                        #63976
                        Dave Hudson
                          Just now I was trying to fix the chain and I must have hit a keystroke that applied some weird shading to one of the chain links… I could not go back far enough in my undos. Anyone know how I can toggle this back to normal shading?
                          #63977
                            @createtaiwan
                            That is one of the craziest things I have ever seen and I have absolutely no idea what is causing it.
                            I do know how to fix it (maybe not the best way, but it works):
                            Delete the culprit. Select an Edge on another link and create a Custom Transformation with it by clicking on the +
                            select the whole link with L, SHIFT+D, Y to move it into place:
                            #63978
                              Found it!
                              You have Custom Split Normals on that one chain. Simply remove them here:
                              #63979
                                And the shortcut you accidentally used is probably ALT+L.
                                #63980
                                Dave Hudson
                                  Wow. Yep. I figured it happened when I was selecting linked items. I think I thought using the ALT key would let me select linked items in a row or something. Thanks for finding this!
                                • The topic ‘COLLAB2021 – Los Habaneros – House Interior Team’ is closed to new replies.
