BC1-1808 Homework, Yukino Hatake
Forum Archive BC1-1808 Homework, Yukino Hatake
Viewing 15 posts - 61 through 75 (of 348 total)
  • #39220
    yukino hatake
      @silentheart00 thank you
      #39221
      Kaj Suominen
        hehe, nice scene. 🙂 liking it 🙂
        #39222
        Wilco Wilbrink
          Very nice submission! You learned a lot in these few weeks. Great job!
          #39223
          yukino hatake
            @louhikarme thank you. i am happy you like the scene
            #39224
            yukino hatake
              @carrotnl thank you i am glad it turned out well. i really learned a lot. trough have still a few questions.
              sometimes i cannot zoom in any closer.
              what is the diffrence with copy and past a object with short c and shift v . and shift d
              #39225
              Aaron Rudderham
                @yukinoh1989 Whilst I’m not sure about the *best* way to stop the lack of zoom in 2.8 (’cause I always used to fix it with local view in 2.79 but we don’t have that yet), a couple of ways are to go into Orthographic mode (hit 5 on the numpad) or hit Shift+F to go into free cam and go to where you need to go.
                For copy paste do you mean Ctrl+C then Ctrl+V? ‘Cause the only thing I can think of is that with Ctrl+C and Ctrl+V is that it allows you to essentially move objects between .blend files, but that’s about it as far as I know.
                #39226
                Jake Korosi
                  So much happening in this scene, I love it!  If you’re this comfortable in object mode you’re going to love it when it’s time to edit mesh.
                  #39227
                  yukino hatake
                    @thecabbagedetective
                    thanks do you also have an idea what ctrl D does then in a different way ? both duplicate  them
                    #39228
                    yukino hatake
                      @jakeblended
                      thanks jake . hope that also goes as well as this. and of i run into issue’ s or have questions i am sure you guys will be there to help out .
                      i am thinking what i gonna try to make but it will be someting with Pokémons again . (wanna get to stay in Pokémon  theme)
                      #39229
                      Aaron Rudderham
                        @yukinoh1989 From what I can tell Shift+D is just a quicker way to do it, but you can only duplicate in that .blend file, whereas with Ctrl+C and Ctrl+V, it allows you to duplicate objects into different .blend files.
                        #39230
                        silentheart00
                          @yukinoh1989 Shift+D creates a stand alone duplicate, meaning you can make separate changes to each object.  Ctrl+D creates a linked duplicate, meaning any changes you make to the original mesh will be reflected in linked meshes.
                          #39231
                          yukino hatake
                            @thecabbagedetective so then you can open 2 blend files and paste them from the one to the other then?. might be handy
                            #39232
                            Aaron Rudderham
                              @yukinoh1989 Yep! That’s pretty much it. One way it’s useful is that you can’t directly import materials from one file to another so you could instead duplicate and object with that material on it.
                              #39233
                              smurfmier1985
                                @silentheart00 I thought the linked one was Alt+D? did I remember wrong..?
                                #39234
                                yukino hatake
                                  @silentheart00 with linked you mean the object will inherit everything you change to the main object then ? Like of you make the eyes bigger all duplicated linked will also change the same way?
                                • The topic ‘BC1-1808 Homework, Yukino Hatake’ is closed to new replies.
