Backhoe Contribution – duerer – Wheels / Rear Axle
Forum Archive Backhoe Contribution – duerer – Wheels / Rear Axle
Viewing 15 posts - 121 through 135 (of 225 total)
  • #58140
    Ingmar Franz
      The double yokes are on both axles in the axle and housings:
      So, my alignment is already correct, but I still can’t imagine how the bar connecting the yoke to the gears in the gearbox can transform its rotation around around the own length axis into two rotations perpendicular to that within the yoke structure.
      #58141
        No way…that’s impressive! I definitely appreciate the work this took but I would have left it as separate intersecting parts…You’ll be a topology wizard by the end of this project, if you aren’t already.
        #58142
          You’ve reached a shocking amount of detail. Super impressive work!
          #58143
            Me trying to read these drawings:
            To me it’s very acceptable to go leave it as you have it; it’s a “looks right, then it is right” situation. Even if it doesn’t make 100% mechanical sense, there’s little to no chance we will see it operating (even if rigged). We’ll likely see these parts in an exploded-view shot for the reel which still doesn’t matter in terms of 100% mechanical sense.
            #58144
            Ingmar Franz
              This was the dog logo before the retopologizing with 10.220 vertices:
              So, after the necessary retopologizing, I only had to do a “Bridge Edge Loop” operation to the now 40 vertices of the outer circle (reduced from 336 vertices):
              The logo now has 3.639 vertices.
              The black parts alone count 2.303 vertices:
              The retopologized logo counted 2.494 vertices before connecting the separate parts:
              #58145
                According to that drawing you are right @duerer!
                That would mean something like this (top view):
                and when the wheel turns:
                #58146
                Ingmar Franz
                  And the three gears in the hub case also play a role that I don’t understand:
                  So, this is my proposal for the “Mystery Files” 😉.
                  #58147
                  Ingmar Franz
                    Off topic: Just found this incredible machine 😁:
                    #58148
                    Ingmar Franz
                      I like these machines where everything engages with each other as in this fun machine here.
                      #58149
                        WHAT!!!??? lol
                        #58150
                          LOL that must be a photoshop job, right?
                          #58151
                            I’m also very impressed with the amount of reference photos you’ve found for your axle and its various pieces. You’re quite the internet detective 🧐
                            #58152
                              As to those three gears: just Google ‘planetary gear’ and find for instance: https://www.youtube.com/watch?v=ARd-Om2VyiE
                              This is the Rumpelstiltskin effect: once you know the name of something/someone, you have power over it/him/her..
                              Or in modern day language: when you know what it’s called, you can Google it…
                              #58153
                                @theluthier you are absolutely right!
                                Look at the 4 repeating ‘humps’ of gravel and then look at the sky above them;)
                                #58154
                                Ingmar Franz
                                  I’m sure that it’s real. Here’s a bigger image version:
                                • The topic ‘Backhoe Contribution – duerer – Wheels / Rear Axle’ is closed to new replies.
