polybook yukino1989
Forum Archive polybook yukino1989
Viewing 15 posts - 46 through 60 (of 227 total)
  • #38544
    yukino hatake
      @procyonlotor
      thank you it did helped. trough if i want the vertical frame to be diffrent should i seperate that part from the frame and rotate it there too ? or is it better to work with uv texturing and unwrapping then ?
      another question . how do i make some kind of group ? like circling around it and calling it for example white wood
      another one brown wood etc ?
      #38545
      smurfmier1985
        @yukinoh1989 I believe not, but  I’m not expert on these things, so you could best ask the Belgium government service where you have to register your company. In the Netherlands its called Kamer Van Koophandel, but I don’t know how it’s called in Belgium.. in the Netherlands they even have get togethers for starting companies where you can ask all these kind of questions, perhaps they organize something like that in your country too? That could be really helpful. Or maybe they have the answers on their website? Hope this helps.
        #38546
        John Sanderson
          @yukinoh1989 it’s kind of up to you and your project.  If you are just doing procedural textures I would probably just separate the pieces (it will be less work), but if you think you may need UVs eventually anyway I would go ahead and do that.  I am not sure what you are wanting to accomplish with the group, but you can make a group by selecting your objects and hitting ctrl G.
          #38547
          yukino hatake
            @procyonlotor good to hear then. I go for seperate pieces. Lesser work is always good 🙂
            #38548
            yukino hatake
              Almost finished the door .I  do have questions when i would want to make a model like for example a door be sallable . Should i model the hinge even further so that when the door opens it also rotates the upper part of the hinge ? And should i also model the hole where the door get locked ? Or are that more like unnessesery details ?
              Let me know if i still can improve it or should take more clear pictures of a certain part .
              #38549
              yukino hatake
                finished the door . trough the place where the door locks with the wall isnt modelled but i am not sure if that is needed?
                this is the basic standard door model (more will be made soon ) i first gonna try to model some diffrent parts and then model more versions 🙂
                #38550
                smurfmier1985
                  @yukinoh1989 Looking good 😊 if you can’t see it through your camera view, then you don’t have to model it 😉 however, if you want to use it as a set for your animations in the future, make sure you don’t see any holes anywhere. As long as it looks complete from all angles your good 👍🏻
                  #38551
                  yukino hatake
                    @smurfmier1985 then this should be fine I can always add the hole for locking the door later.
                    Now onto the window 😀
                    #38552
                    Scott McClellan
                      @yukinoh1989 … Just browsing through your polybook. Very complex building layout you’re attemepting. Can’t wait to see it in action. Love the company name. Been playing with one myself – one of the reasons I started looking into 3D work. lol.
                      #38553
                      Scott McClellan
                        @yukinoh1989 … Nice looking door. And yeah, what Miranda said – if you can’t see it, don’t model it (unless you’re extremely OCD. lol)
                        #38554
                        yukino hatake
                          @pffsfs thank you so much. I am happy you like the shape of the building and the door. What does OCD means?
                          #38555
                          Scott McClellan
                            @yukinoh1989 … Obsessive Compulsive Disorder. Meaning a person would have a tendency to model every little detail about the door should you be able to see it or not. 🙂
                            #38556
                            yukino hatake
                              @pffsfs now that make sense xD but gladly that is someting i dont have 😀
                              i still gonna have a ton of work so better to not worry too much on too small details xD
                              #38557
                              yukino hatake
                                does anyone know if sketchfab is already compatible with 2.80 beta ? or is it still not possible to upload2.8 models ?
                                #38558
                                silentheart00
                                  @yukinoh1989 I would imagine not considering it’s beta and not a full release.  So many things will change on the code side of things it’s probably best for Sketchfab to wait until the code is finalized, which it will be for release, whenever that is.
                                • The topic ‘polybook yukino1989’ is closed to new replies.
