Collab2021 – WIP – vincav81
Forum Archive Collab2021 – WIP – vincav81
Viewing 15 posts - 61 through 75 (of 76 total)
  • #66063
    Vincent
      @sheila5 Thank you. I’m only just a few minutes home from the day surgery. Now it’s just getting through the 2 day ramp-up of the pain and the following 4 day ramp-down back to how my mouth felt beforehand.
      #66064
      sheila5
        I have had so much dental work done, I can feel you. Usually I just play world of warcraft to forget the pain
        #66065
        George Sangeorzan
          @vincav81  your cart looks super. I like the fact that it looks robust and doesn’t feel like it will brake in half when lifting it from the handles. All the best wishes on your wisdom tooth op (no pun intended 🙂 )
          #66066
          Vincent
            @simonsez11 Thank you.
            #66067
            Vincent
              Here’s my cart with a very basic noise dust/grunge effect using a method similar to Kent’s Z Normal.
              It took maybe 5 minutes to set up? The grunge is only on my local copy and not the Google Drive. I’d only add it if might added to the scene or not. But as you can see below, the grunge is only really visible from close up.
              Rendered View, Close up.
              Rendered View, Main Camera.
              As you can see any subtle accent like grunge/mud wouldn’t add anything to the final composition.
              #66068
              Carlo
                @vincav81 Very nice cart, looks great!
                #66069
                Vincent
                  Homework Submission – Week 4 – Cart Turnaround
                  Here’s my Week 4 Turnaround animation. @theluthier @duerer
                  I used the shadow catcher effect by Louis du Mont to create the infinite background effect.
                  The Shader to RGB node setup for the shadows.
                  And the setup for the Background colours. I tried my best to select the relevant colours from Vadim’s artwork.
                  NB: this is all on my local copy, the Google Drive Master is just the cart without any background effects.
                  #66070
                  Vincent
                    And here’s a still frame for @elubie and @splat21‘s records.
                    #66071
                    Andrea Weikert
                      Awesome work and a very nice turnaround! Very cool shader trick for the background and shadows, have to try this out one day.
                      #66072
                      splat21
                        @vincav81, great work and nice money shot!  I definitely like the infinite background and the world lighting.  Nice touch.
                        I have already framed your image and will post it on the blog today.  It really looks great!
                        #66073
                        Ingmar Franz
                          @vincav81 That’s a dream of a cart appropriately presented👍! Thanks for sharing your node setups and escpecially the trick for the infinite background I’ll definitively try that out myself 😀!
                          #66074
                          sheila5
                            Hope you feel better. Your work didn’t suffer from your painful treatment. Looking great
                            #66075
                            Ingmar Franz
                              @vincav81 Thank you, for sharing your tests concerning the importance of grunge on the cart. We will have to wait for the final camera animation in order to determine whether some grunge is needed. But I could well imagine that we’ll have a closer look at the cart 😀!
                              #66076
                              Ingmar Franz
                                @vincav81 Your cart is definitively an eyecatcher 😀!
                                #66077
                                  Look at that presentation! Truly presenting your cart in the best possible light. Very nice job @vincav81 👏
                                  You’ve done great work with your card. You can kick back and relax the rest of the week. Thanks for joining the project. It was a pleasure working with you 🤝
                                • The topic ‘Collab2021 – WIP – vincav81’ is closed to new replies.
