BC1-1808 Homework, Yukino Hatake
Forum Archive BC1-1808 Homework, Yukino Hatake
Viewing 15 posts - 256 through 270 (of 348 total)
  • #39415
    yukino hatake
      @smurfmier1985
      hey i have some problem (since i am not used to work in 2.79 i dont know what the problem is nor fix it)
      when i try to render someting strange is happening . no mather  how close or far my camera is the result stay the same .
      this is the latest file of my eevee project.
      eevee blend file
      i really hope someone can help to figure out what the problem is .
      #39416
      silentheart00
        @yukinoh1989 You can totally do it all on your own.  It’s going to take some time and a lot of hard work, but you can totally do it.
        #39417
        yukino hatake
          @silentheart00 That is awesome to hear. with more people ,things will be faster and easier but i am glad to hear its possible to do it all alone too. question do you perhaps know what is wrong with my blender file ? i cannot take a render anymore. it looks really strange. the file is posted in the previous text
          #39418
          silentheart00
            @yukinoh1989 I’ve seen the problem you’re talking about in my own fiddling, but I have no idea what causes it.  Try selecting the camera, then go to View->Cameras->Set Active Object as Camera and if that works.  If not, then delete the camera, add a new one, and Set Active again.
            #39419
            yukino hatake
              @silentheart00 hey thanx i didnt finded it at first but after going into spacebar and type the function of worked
              #39420
              yukino hatake
                eevee wip
                #39421
                smurfmier1985
                  @yukinoh1989 nice! 😃 That shape is looking goood
                  #39422
                  yukino hatake
                    @smurfmier1985
                    Thank you . got a update . still not as i want (is there a way when you made a crease to smooth it so the geometry fuse together agian ? right now each time i use smooth with inflate and then smooth again the crease is coming back 🙁 . )
                    but overal for working the whole day on the fur i think it came out pretty good already  .
                    this will be frozen. (she has the lightest collor of us all (might ajust the collors later but i think i am not that far from the good collor . ) after i finish her ill start the other 2 .guess who she will turn into later :p
                    edit added 2 more lights to get a better collor
                    #39423
                    smurfmier1985
                      @yukinoh1989 That’s looking nice!! 😄
                      Just making sure I understand it right, you want the crease to disappear completely? Make sure dyntopo is on and that it’s on ‘subdivide collapse’ (subdivide edges doesn’t regenerate geometry). You can use inflate/blob/clay strips to fill the crease. Make sure you smooth on a lower strength so it doesn’t go to hard. Normally that should work.
                      Frozen eh, hmm.. maybe Fire is next?
                      #39424
                      silentheart00
                        @yukinoh1989 Looks good so far.
                        #39425
                        yukino hatake
                          @smurfmier1985 thanks so much . gonna try it out tommorow. got as bit of a headache or how is that called(hoofdpijn) are there parts that looks strange? if so be sure to point them out since i plan to use them for later animation. so they should be perfect 😀 . for the painting on the tail i still have to figuren out how to do that .
                          and who knows 2 more to come :D.
                          #39426
                          yukino hatake
                            @silentheart00 Thank you silentheart00 . i am happy to hear you like it. still have a lot to do but i will do my best to finish at least the 3 eevee’s
                            #39427
                            smurfmier1985
                              @yukinoh1989 The shape of the fur looks really good, just a bit more attention to smoothing the creases they are a bit too much now, but as you said you did have difficulties with that so you’ll get to that tommorow. You’re ok the right track 😊👍🏻
                              Headache is the right word for it yes, and that sucks.. have a good nights rest hope it’s cleared up tommorow!
                              #39428
                              yukino hatake
                                @smurfmier1985 awesome to hear . gonna try to refine it when i get from work. and thank you sadly still have a headache but maybe i should just go take a bit more sleep. so its possible i wont stay till end.of livestream today if it isnt yet better.
                                #39429
                                Jake Korosi
                                  @yukinoh1989 That’s looking awesome so far!  Keep it up!
                                  Smooth should be getting rid of the creases, I do not know why they would be coming back – perhaps make sure that your Dyntopo method is set to “subdivide collapse” instead of “subdivide edges” when performing that action, is all I can think of.
                                • The topic ‘BC1-1808 Homework, Yukino Hatake’ is closed to new replies.
