BC1-1808 Homework, Aaron Rudderham
Forum Archive BC1-1808 Homework, Aaron Rudderham
Viewing 15 posts - 136 through 150 (of 314 total)
  • #38982
    smurfmier1985
      @thecabbagedetective I’ve put your Clank and the picture you showed us the first time next to eachother and drawn some lines to test the proportions. They don’t have the exact same posture, however it’s close enough to get an idea of the ratio you need.
      I think it is indeed a bit off..  The head is pretty close, but the body is too high, it should be a bit more squarish. He’s a compact little dude 😁
      Here’s the pic:
      #38983
      smurfmier1985
        @thecabbagedetective Also took a look at your topology, hope you don’t mind and that you can read my terrible handwriting:
        I thinks that would make it all quads. Hope this is helpful!
        #38984
        Julian B
          @thecabbagedetective Is there a possibility to blur environment maps/ HDRIs/ background images in Blender or did you use another software to do that? I only found tutorials of people using Photoshop for it.
          #38985
          Andres Altuve
            @thecabbagedetective  Thanks!! this has helped me a lot, I will do some tests in my model!
            #38986
            Andres Altuve
              @smurfmier1985 If he removes those edges, does the sharpness in the corners stay? Thanks
              #38987
              smurfmier1985
                @aaltuvem Yes, those stay. The edges I’m suggesting to change are not near the sharp beveled edges at the corners, but more in the middle, so those nice sharp edges should be fine 😊
                #38988
                Andres Altuve
                  @smurfmier1985 Thanks for the tips!! I will do some more tests on my side.
                  #38989
                  Aaron Rudderham
                    @smurfmier1985 Oh wow the difference is insane, feel really stupid not noticing that, thanks. Also believe it or not but there’s not a single tri on that model, they’re all quads, but they’re merely bundled together. I’ll still try applying your (or a variation of ) advice though, so thanks again.
                    #38990
                    Aaron Rudderham
                      @bsdwerbeagentur Well what I actually did in this render was to place a Plane behind the model, then give it a material with the Principled BSDF shader, ramped the Metallic to 1 and set the roughness to 0.1, which caused the HDRI to reflect in a blurry manner. Though surely you could blur the HDRI/background image with enough DoF, no? I haven’t experimented enough to find out.
                      #38991
                      silentheart00
                        Yeah!  Looks good!
                        #38992
                        smurfmier1985
                          @thecabbagedetective Ah now I see when you zoom in like that 😊 No probs! And no need to feel stupid, when you’re focused on the modeling part and making things nice, sometimes other things get a bit lost out of sight. Easily fixed so nothing to worry about!
                          #38993
                          n647
                            Great work so far, and yea shrink wrap to stick to the base shape is a good technique specially when working on curves and spheres, but any projection will have a bit of deformation so you may need to compensate for that o nthe mesh before the project.
                            on the model itself I would say heads and limbs need to be a bit more bulky specially the jaw, also are you using the auto smooth?
                            #38994
                            Zsolt Cseh
                              Day 3 done!
                              @thecabbagedetective Aaron before you would touch the proportion differences of this version would like to write – that I like yours one better than the reference.
                              It is so cute in this format, it got an own interpretation and by that personality, looks so great
                              #38995
                              Aaron Rudderham
                                Day 4 done!
                                Well, done probably isn’t the word I’d use. “Passed by” is more appropriate, due to being so busy with other stuff I didn’t get much done. Spent my entire time taking feedback reproportioning and remodeling certain areas. Good in a way though, gives me more stuff to work on on Week 4, thereby making it feel justified that I’m dedicating a week to that. Still not completely 1:1 but I think it’s close enough so that I’m happy* with it.
                                Don’t forget to enable “denoising” in the scene layer panel, this could save you soooo much time in rendering! With that done, have a good one!
                                *pleased for like a day until I see the flaws and become overly critical
                                #38996
                                Aaron Rudderham
                                  @n647 Cheers for those pointers, they helped out! And nope, never really touched it, maybe that’s something I should get around to doing…
                                • The topic ‘BC1-1808 Homework, Aaron Rudderham’ is closed to new replies.
