Backhoe Contribution – duerer – Wheels / Rear Axle
Forum Archive Backhoe Contribution – duerer – Wheels / Rear Axle
Viewing 15 posts - 91 through 105 (of 225 total)
  • #58110
    Ingmar Franz
      You’re absolutely right, @spikeyxxx , with being very carefull with vertex weights. I’m currently experimenting a lot in order to avoid any steps due to shrinkwrapping or, if I can’t (easily) avoid them, bring me at least into a good position for final polishing after having applied the modifiers.
      #58111
      Ingmar Franz
        The gearbox consists now only of quads, but the shrinkwrapping still needs some tweaking, especially at the yellow pads on both sides of the gearbox:
        #58112
        Ingmar Franz
          And this is my rear axle now with the all-quads gearbox:
          #58113
          Ingmar Franz
            This is now one continuous all-quads-mesh:
            #58114
            Ingmar Franz
              Another part connected to the left:
              Only the gearbox side ring still has  to be connected
              #58115
                That is looking really good @duerer! Both the shape and the topology.
                I love this slight ‘bulge’ in this ‘new’ part when it goes from ‘square’ to circular; gives it this almost organic look of cast iron.
                #58116
                Ingmar Franz
                  Thanks a lot, @spikeyxxx 😀!
                   I had to dissolve many edges at the green-blue part on the left side and bring the circular shape back to perfect circles with “Loop Tools”. The edges (marked with a more saturated yellow) are beveled. I duplicated one edge area and used it as snapping target for the resting three in order to get an even look.
                  At the magenta bolts holder, I made the edge loops run down straight from the holes to the axle bottom instead of directing them into the corners nearby because this caused a lot of edge stretching so that some faces were overlapping which was clearly visible.
                  The holding edges at the corners  of prodtruding parts are always a challenge, escpecially when they run into curved surfaces. I have a mix of solutions which all aren’t 100 % perfect (I don’t know whether this is possible at all?) but some slight pinching is only visible if you come very close and  I can at least live with it. Maybe you can have a look at it when I post my finished file?
                  #58117
                    How true and I think you solved that quite beautifully!
                    Here’s an example of what I did:
                    When using one of the extreme Matcaps you can see some stretching, not even a lot. But now look at the mess I made of this in Edit Mode:
                    I’ll be happy to take a look when you’re finished, but what you’ve got so far looks great, I can tell that from the screenshots already.
                    #58118
                    Shawn Blanch
                      Whoah.
                      #58119
                      Ingmar Franz
                        I use the “Shrinkwrap Modifier” in order to project the outline of the cutting surface of the part that I want to connect to an object and do the same with a scaled up version of that outline as holding edge loop.  Round objects are easier to connect since they don’t cause as much stretching as objects with angular cutting sufaces.
                        #58120
                        Ingmar Franz
                          I added recesses for the gearbox bolt nuts, but it’s not yet all quads:
                          #58121
                            Didn’t notice this before, but there is some pinching here:
                            might be easy to solve, by merging those three close-together edge loops at the bottom.
                            Something like this:
                            and:
                            Might not work in your case, but it’s worth a try.
                            Don’t stress out too much if you can’t solve it, with the right shader (dirty, greasy, damaged, painted iron) you’ll be able to hide it;)
                            #58122
                            Ingmar Franz
                              Thank you, @spikeyxxx, for the hint 😀!
                              #58123
                              Ingmar Franz
                                And it worked very well (!) 😀:
                                #58124
                                Ingmar Franz
                                  Now, the gearbox side rings and the green-blue part are all quads and without any 6-poles:
                                  The green-blue element to the right of the gearbox is a mirrored in global Y duplicate of its axle left side counterpart.
                                • The topic ‘Backhoe Contribution – duerer – Wheels / Rear Axle’ is closed to new replies.
