Backhoe Contribution – duerer – Wheels / Rear Axle
Forum Archive Backhoe Contribution – duerer – Wheels / Rear Axle
Viewing 15 posts - 46 through 60 (of 225 total)
  • #58065
    Ingmar Franz
      Here’s an old version of the main body of my rear axle end housing with booleans (but only those for the bolt holes):
      https://www.dropbox.com/s/bhpk4e9cvewafno/RearAxleEndHousing_OldBooleanVersion_4Juli2020.blend?dl=0
      I’ve also cut out and magnified a drawing of this part from an earlier post in this thread which seems to show some kind of contour lines that can maybe give a hint on how to do a proper topology in order to match the exact shape:
      #58066
      Shawn Blanch
        Yeah it looks like you struck gold those are nice hintful lines.
        #58067
        Ingmar Franz
          So, here an update on my rear axle:
          #58068
          Ingmar Franz
            One new part modeled (called “yoke”?) that can be seen from outside the rear axle end housing under certain angles:
            File is here.
            #58069
            Ingmar Franz
              Some alignments done. The most important is this one in order to avoid intersections:
              #58070
              Ingmar Franz
                And that’s the newest version of my rear axle:
                #58071
                Ingmar Franz
                  Connecting the different parts of the gearbox especially certainly will bring a lot of fun 🤪.
                  #58072
                  Shawn Blanch
                    Am I reading that correctly? 10 million faces? Jeez you are a beast Ingmar!
                    I think it is really coming together quite nicely my friend!
                    #58073
                    Ingmar Franz
                      Yes, and Kent definitively will like that almost 10 million faces 😉😁! The new “yoke” part has already 2640 faces. And there’re two of them. Some parts are still too much subdivided where the “Subsurf Modifier” alone could do a good job (for example in the wheel hub and rim). But since this rear axle is really complicated, I don’t know how low I can push this.
                      #58074
                      Ingmar Franz
                        Off topic: Did they switch off here in the forum the redirection directly to a new reply? I have to search for “hours” as a workaround.
                        #58075
                        Ingmar Franz
                          I cut into gearbox using a technique by Josh Gambrell here (but my circle has 16 vertices instead of 12 in Josh’s tutorial)
                          and after this the shrinkwrap technique again for smoothing out distortions. The  shrinkwrap target uses one subdivision more than the shrinkwrapped mesh in order to remove even the most subtle shading issues.
                          Thanks to @spikeyxxx for this tip in the backhoe modeling forum here and thanks to @theluthier for his tutorial on this technique in the backhoe livestream #3 beginning here at 1:53:18.
                          The gearbox file is here.
                          #58076
                          Shawn Blanch
                            I love that tutorial by Josh. I used that A LOT on most of my cylindrical intersections. It looks quite nice. I also saw a tutorial by masterxeon001 here that covers a more complex case (I think he meant to make 2 different cylinders with different sides to teach the topic can apply whatever way you come across it):
                            I do have a question @duerer how do you reference someone’s posting so that it immediately goes there? I really like that feature.
                            #58077
                            Ingmar Franz
                              Thank you, @blanchsb , for the link to masterxeon001’s tutorial.
                              To your question: You reference a posting by right clicking on the date / time of the posting directly under the author’s name and then choosing the context menu’s entry for copying the link.
                              #58078
                              Ingmar Franz
                                I’m trying to join the small yellow pads  with my gearbox:
                                File is here.
                                The shrinkwrap targets are causing the z-fighting. The red target is only used for correcting distortions caused by the hole cut in for the protruding orange part. I’m referring in this post only to the pads on the two siderings. Only the left ring has the blue shrinkwrap target since the right ring is just created by mirroring.
                                #58079
                                Ingmar Franz
                                  I’ve reshaped my rear axle end housing:
                                  File with that part only is here.
                                • The topic ‘Backhoe Contribution – duerer – Wheels / Rear Axle’ is closed to new replies.
