Backhoe Contribution – Blanchsb – Exterior Loader Arms and Interior Chair
Forum Archive Backhoe Contribution – Blanchsb – Exterior Loader Arms and Interior Chair
Viewing 15 posts - 46 through 60 (of 216 total)
  • #56854
    Shawn Blanch
      @adrian2301 yeah that is a different loader arm design, the 430F that I got pictures of uses that. The side pieces mount on both sides for that design and there are two pieces where my “one” red piece would be.
      #56855
      Shawn Blanch
        Here’s another viewpoint where I talked about it with things shifting to be centered like people are suggesting and why that obviously is not going to work. I can try to shift stuff over like @pfbourassa Parker has suggested but man all of the reference that I see these top yellow pieces that hug the red piece are really close together. So I am at a loss of what to do unless I widen the loader arms like in this photo
        Crap…….I found the issue. The loader arms spread out just like in the picture above………..dun dun dun! I found the loader arm design we are using and it is doing the same thing. I can’t post the picture though. We already have this picture in our forum so I don’t feel bad posting a higher quality one even though it is not exactly our model. Took a look around in my special access and yup. I did it wrong. That’s a bummer. I get to spread that loader arm out now. I’ll see if I can fix it tonight and resubmit.
        #56856
        Parker Bourassa
          Huh, that’s a surprise! But I’m glad you figured it out.
          #56857
          Shawn Blanch
            I’ll really try to get this working and resubmitted by tonight or tomorrow so that you have something to work with Parker. You’ve waited long enough for me to mull it over haha. We need to connect that bucket so the magic can start happening.
            #56858
            Parker Bourassa
              This is why I kept those parts flexible so far. It looks like my “fins” are still straight, so I’m not exactly sure how that junction will end up working.
              #56859
              Shawn Blanch
                @pfbourassa. I have submitted the revision on the group sheet. As long as Kent doesn’t see any issues. I plan on leaving the connection points where they are. The bottom piece connects to 1 fin and the top to a different fin, just FYI. Reference pics here in this forum from Adrian for more info.
                #56860
                Shawn Blanch
                  My first draft at the hydraulic lines from one assembly to another. I’ll work on the piston hydraulics tomorrow hopefully.
                  @adrian2301  There is a tank near the rear of the loader arms Between the aft pivot points that sits on the chassis and below an overhead support. The tank is vertical and looks similar to a fat radiator without the fins haha. That holds all of the hydraulic oil to my knowledge. Have you seen it along with the other hydraulic connection points for the front?
                  #56861
                  Adrian Bellworthy
                    Do you mean this one:
                    This I found is the tank for the hydraulic fluid and supplies all hydraulics. It sit above the gearbox. The lines from here go to the control valves which are attached to the chassis, then on to the individual pistons. I may go as far as the control valve, and then reassess and decide if it’s really worth going to the tank. With the gearbox installed this will probably not be seen.
                    #56862
                    Shawn Blanch
                      Yup that is the one I believe. I agree it is probably never going to be seen.
                      #56863
                        Looks great @blanchsb. Funny how satisfying a well-formed hydraulic line can be to my inner 3D modeler.
                        #56864
                        Shawn Blanch
                          Yeah they are extremely satisfying, perhaps because you see results more quickly?
                          #56865
                          Shawn Blanch
                            Was able to work some of the finer details today on the upper hydraulic supports and added some jubilee clips to the metal bands. I left the threads on the screws off, but I think it looks passable……. except I made them the wrong direction against the holes. I’ll have to correct that tomorrow haha.
                            I also added the zerk fittings to the loader arms:
                            They should be to scale but man do they look small compared to everything else.
                            #56866
                            Shawn Blanch
                              I completely redesigned the jubilee clip band using a template bezier circle and two base thin band meshes. One piece represented the band with the tightening cut-out slits and the other represented a solid band.
                              I assigned them both to the bezier circle to start with.
                              Once I got it all into position around the piston I duplicated a small section of the bezier circle and separated it to a separate piece. Then I cut a small portion of that duplication area out of the original bezier circle just below the tightening screw.
                              Then I assigned the base mesh band with slits to the smaller portion of the separated duplicate.
                              So two pieces fitting into 1 per-se. I haven’t mated them up yet but I thought I would share my thought process. This actually took me all night to think about haha.
                              Hopefully that makes sense. Maybe @spikeyxxx could recommend a better process but I think I was being clever this time around.
                              I’ll make the individual jubilee clips a little more unique tomorrow but that is an easy task of just moving the small bezier curve around a little. It would be nice to know if there was a way to join the two pieces together easily. I may just apply the mods once I am happy with it and do a quick merge since it is only one section that needs to be mated from the two band base meshes.
                              #56867
                                Looks great Shawn! Good technique as well.
                                I’d do it almost the same, but with only one mesh..
                                Make a loop cut on the ‘cylinder’ and slide it into place. P > Separate by Selection. Take that new piece in Edit Mode and delete one vertex (where overlapping should occur). Convert the Mesh to a Curve and extrude the overlapping end:
                                Then you can model the band straight (as one piece and a bit better than I did here):
                                 and add a Curve Modifier:
                                #56868
                                Adrian Bellworthy
                                  @blanchsb  I decided not to add more detail to the control valve at the moment as it most likely won’t be seen. I only modelled it as a reference point where the lines start.
                                  HERE IS THE FILE
                                • The topic ‘Backhoe Contribution – Blanchsb – Exterior Loader Arms and Interior Chair’ is closed to new replies.
