Match your favorite lighting example
Forum Archive Match your favorite lighting example
Viewing 15 posts - 46 through 60 (of 117 total)
  • #31702
    Jasmine Wongus
      Okay, I did another one, and though it didn’t turn out exactly how I wanted it to, I got pretty close!
      The original image is from Ewa Wierbik: https://www.artstation.com/artwork/LXQyP
      I used an image of rocks for a light texture almost depicting tree leaf shadows. 😀 That was a creative twist for me! It took a while to really get the right angle as well, and I still was off some. Also, getting an HDRI that could closely match that background, hard stuff. I had to actually use an overcast image! I may try this one again sometime, because the challenge was good! (I even used parts of a black cube to bring out more of the tree shadows’ “shadow”.
      #31703
        Ok this is exercise #4. Kinda tricky with all the hair particles. Turns out I remembered quite well the old Kent tutorial of stylizing hair with all the curls. Massaging with patience the different layers of hair. The image isn’t very faithful to the reference, but it was great practice. This exercise series have been a boss fight, lots of XP to be gained.
        #31704
          Nice one @jazze. The lighting-through-leaves is a tricky thing to pull off, so well done! Not sure I’ve ever had to use a light texture before. Good solution 👍  Perhaps the mug shader could be critiqued a bit, but that’s not really the focus here.
          #31705
            Wow, Omar – Look at that Blue rim light! Felt like I had to capitalize “Blue” lol. You really nailed the match. And even the hair resembles the example closely! Great job all around. Fun example too.
            #31706
              I had to do another one. The utter simplicity and drama of this setup grabbed me. Couldn’t help but give it a go!
              #31707
              Matthew Fricker
                Great work Kent , I love lighting setups like this that are dramatic and have a nice balance of lit detail and form revealing silhouettes. Cool model too!
                #31708
                Matthew Fricker
                  Haha , cool idea Omar, and really nice hair. Santa-Baker looks great with the blue rim. How much of it was post?
                  #31709
                  Matthew Fricker
                    Great work Jazze, Perhaps crank up the exposure and contrast a little to darken the shadows and brighten the highlights? Although that is really post-processing so not technically required 🙂 . I love the light filter you used, you got it spot on!
                    #31710
                      I should probably turn this topic into an official Exercise. That way you all can get XP for submitting..
                      #31711
                      Jasmine Wongus
                        Oh, that would be a wonderful idea!
                        #31712
                        Jasmine Wongus
                          Omar, I had to drag each of my goal images into Google Images, and it does a backward kind of search for the origin! Try and see if that’ll work for you!
                          #31713
                            Yeah I can try that. Is the credit for some legal reason or just common courtesy?
                            #31714
                            Cody Winchester
                              Another lighting attempt. The blue is slightly off as it was hard to really nail down the correct tone and the floor is not as brightly lit.
                              Based on this piece https://www.artstation.com/artwork/Kz3DR
                              #31715
                              Jasmine Wongus
                                Wow…so good!! 😀 It’s really close, you just need a little more contrast to bring out the highlights and shadows! You actually have a touch of a cooler hue, that’s all. 🙂
                                I love this exercise, it’s so fun!
                                #31716
                                Addyson H.
                                  I’ve been working on a scene which I put in my usual thread and Jonathan Lampel suggested I submit to this challenge. Here it goes!!
                                • The topic ‘Match your favorite lighting example’ is closed to new replies.
