Collab2021-WIP-PFBourassa
Forum Archive Collab2021-WIP-PFBourassa
Viewing 10 posts - 46 through 55 (of 55 total)
  • #67205
    Adrian Bellworthy
      Good to hear.
      Did you see Kent’s casual stream on Thursday, he covered mostly nature assets, a good example of the bushes.
      #67206
      Parker Bourassa
        Trying to get my placements correct. I copy-pasted some geometry from the scene file, and I’m placing bushes around the seams where different objects meet, and I’ll put some at the bottom of trees to hide the trunks.
        Here’s what each bush looks like up close.
        And from the main camera.
        Still working on the colors. I’ll need to consolidate my PNGs into one big image I think.
        #67207
        Jonathan Lampel
          Aha! I was looking in the WIP instead of the TEMP. Got it 👍
          #67208
          Jonathan Lampel
            This is great! The textures weren’t in the drive (as far as I could find) but the screenshots show enough. If you happen to have extra time, you could experiment with giving the bushes a soft and blobby bump map to see if that helps give it some depth from farther away. You could also try giving a simple curve like below to test if it picks up more of the direction of the lighting. I haven’t tried it myself with the textures so it’s just a theory.
            Beyond that, I don’t really have any critiques. Keep doing what you’re doing and it’ll look great!
            #67209
              @pfbourassa Glad to see you’re keeping with this project! I see your latest WIP .blend but textures aren’t loading. I’m keen to see your card-based bushes which should work well with @tijnkroons card-based trees for the BG 🤝
              #67210
              Parker Bourassa
                Homework Week 4 – BG Bushes
                @theluthier I think I’ve uploading everything correctly, and I think I’m done?
                I put all the “clump” textures into one 1024×1024 PNG :
                And I placed a few unique bush shapes around the scene. If you want to duplicate the collections, feel free. I linked in enough reference geometry from the scene to help with placement.
                And the material is set up to easily change the color if needed.
                Just duplicate the material, and change the color ramp.
                Again, I’m not super clear on what’s needed, but I tried to make it easy!
                #67211
                splat21
                  @pfbourassa, it looks like you are finishing up with your project.  I’d love to post your artwork in the TSMF Blog.  Please let me know if you create a money shot.
                  #67212
                  Parker Bourassa
                    These bushes don’t really have a money shot as they play such a background role. They kind of look bad close up. And I don’t have access to the final lighting setup (or do I? Honestly not sure)
                    But feel free to use any image in this thread for the blog if you want.
                    #67213
                    splat21
                      @pfbourassa, I am sorry, but I don’t see a “money shot” within the images you posted.  Even if they looked bad up close, they would demonstrate a low poly model that was designed for the background.  If you get access to the final lighting setup and create an image that you want me to post in the blog, just comment me in your WIP and I’d be happy to do so.
                      Also, congratulations in completing the project!  I bet it feels good.
                      #67214
                        You synced everything correctly @pfbourassa 👌 Nice work on the bushes! Here’s how they look in the assembly:
                        I’m on the fence about them…Even though they were structured the same as tijn’s trees (perpendicular cards) the bushes feel noticeably more flat and billboard-y. I added some curvature to the flat planes but it still doesn’t solve it for me.
                        Perhaps the gibli method results in a much less leafy feel than the rest of our foliage. I’ll think it through some more. Still it may be fine for the background.
                        I’m really glad you joined the Collab! As always it’s been a pleasure working with you  🤝
                      • The topic ‘Collab2021-WIP-PFBourassa’ is closed to new replies.
