BC4-1810 Homework, Grady Pruitt
Forum Archive BC4-1810 Homework, Grady Pruitt
Viewing 15 posts - 16 through 30 (of 57 total)
  • #42282
    Grady Pruitt
      @silentheart00 I think you’re right.. just needs a subtle shift towards cyan. Still, I like how this looks.
      #42283
      Morten Fjellheim
        @gradyp This is going the right way:)
        #42284
        silentheart00
          @gradyp Day and night scenes look nice.
          #42285
          Grady Pruitt
            This is just a WIP shot.. So far, just got the base material/colors in. Still have to work on the car paint texture, and some decals, but some good progress tonight on this week’s assignment I debated between doing this one and a 1957 Chevy BelAir Sedan. I went with this one because I plan on going back and doing the Bel Air while going through the vehicle course I missed a few months back (and this one was free, compared to the other ๐Ÿ˜€ )
            Model is by Natman on BlendSwap,
            One thing I’m noticing is Eevee isn’t doing transmissive materials.. Either that, or I’m doing it wrong.
            #42286
            Pavel Mazanik
              @gradyp It can! You just need to enable some settings.
              First of all, you should enable Screen Space Reflections and check the “Refraction”
              The second – you should go to your materials tab and enable “Screen Space Refraction” checkbox. You can also set the approximate “glass” thickness here (refraction depth).
              And then you can tweak your principled bsdf node transmission and IOR values to get what you want.
              #42287
              Grady Pruitt
                Not as happy with the matching aspect of this one, but I do like the result. I may keep looking for a better one to work from and/or trying to match this closer.
                #42288
                smurfmier1985
                  @nekronavt you really are an eevee guru Pavel! ๐Ÿ˜„
                  #42289
                  Grady Pruitt
                    @nekronavt , I have to agree with @smurfmier1985 … Thanks! that was exactly what I needed ๐Ÿ˜€ At least…to make the glass see through ๐Ÿ˜€ Been wondering about that for a while ๐Ÿ˜€
                    #42290
                    Pavel Mazanik
                      @smurfmier1985 probably more like google guru ๐Ÿ˜‚
                      @gradyp you are welcome ๐Ÿ™‚
                      #42291
                      silentheart00
                        @gradyp Hey, good start on your car!
                        I think the coloring with light exercise is a bit difficult when the model is colored, but it’s decent.  The blue could maybe be a bit more saturated or a little lower intensity or both.  I think the warm one matches well enough.  Good work.
                        #42292
                        Grady Pruitt
                          This one is coming along quite nicely I think. Still a bit of work to be done, but I like how this is progressing
                          #42293
                          smurfmier1985
                            @gradyp Much better than the first render, great progress! ๐Ÿ˜Š
                            #42294
                            Grady Pruitt
                              Mainly fixing the windows made it look better ๐Ÿ˜€ but also started working on the actual paint and not just base colors ๐Ÿ˜€
                              As for my color match.. I like this attempt better than my previous for this week, but feel it’s still off, and my suspicion is that I’m not matching the base color of object more than the lighting. Also, in working on this, I found this particular target has 4 lights… Key, fill, and 2 rims.. one on either side.
                              #42295
                              silentheart00
                                @gradyp It’s coming along!  Your second color match is better, I think.  Maybe the key light is a bit strong, but that’s a tiny thing.
                                #42296
                                smurfmier1985
                                  @gradyp Much better than the previous one ๐Ÿ˜Š๐Ÿ‘๐Ÿป
                                • The topic ‘BC4-1810 Homework, Grady Pruitt’ is closed to new replies.
