Eralp Orkun Cihan
Forum Replies Created
  • in reply to: What is the password of the videos ? #88894
    Eralp Orkun Cihan
      Thanks a lot! Yeah i realised when i try to go to their homepage afterwards.
      in reply to: Where has the Vertex Colour node gone? #83989
      Eralp Orkun Cihan
        Why would I want to install older version as the new versions should be more developed versions. I can’t think myself to change to older versions to just do 1 job and then go back the new one again.
        in reply to: Light Path Node #87937
        Eralp Orkun Cihan
          I can understand that it can be because the glass is just a plane. But when i give a thickness then from outside it looks like the moneky is just a sticker on the glass so it changes where the monkey is and this way is introduced as “architectural glass” which is my field and there is no glass like that in any architectural visualisation software, it looks just weird.
          in reply to: Source File #87067
          Eralp Orkun Cihan
            Hey Adrian, Thank you. Yes i found the torso, i was meaning the full body character in the first video. But thanks
            in reply to: Is it the only way ? #86672
            Eralp Orkun Cihan
              I am not saying like house takes too much effort, i guess your answer is a bit weird way to explain. Let me explain in your way: It is more like he is trying to build the house with single piece of stones (in term: Masonry Structure) and i am saying there should be easier or closer way like just making with concrete instead of putting each stone one by one. That is why your example has nothing to do with what i am asking. I am beginner in this software, not in 3D and this way is the longest ways i have ever seen in between all the softwares i am using.
              My question is more like: Can not we add the circles first as objects, then cut out the parts which intersect with the speaker surface. or placing the circles on the speaker’s surface then insert-move down. I hope this explains better than my first comment. If this is the only way, of course i will try to get used to it but i am looking for a reasonable example or answer.
