“Industrial Environments with Eevee” Course: Columns Turning Magenta when Mixing in Second Principled BSDF
Forum Archive “Industrial Environments with Eevee” Course: Columns Turning Magenta when Mixing in Second Principled BSDF
Viewing 15 posts - 1 through 15 (of 28 total)
  • #13991
    Ingmar Franz
      The problem has already been described by @chapeline here and on “Blender Stackexchange” here (but without any fitting solution for my problem). Despite exactly following Kent’s @theluthier instruction, the columns nevertheless turn magenta as soon as the second “Prinicpled BSDF” is mixed in with a “Mix Shader” node:
      After muting the “Mix Shader Node”:
      With just the “Principled BSDF” with the paint color beeing plugged into the “Material Output” node:
      Everything fine in Cycles:
      All tests run with Blender 2.92.0 and 2.93 Alpha.
      #68708
      Ingmar Franz
        A partial solution posted on “Blender Stackexchange” here. But I’m still wondering why Kent @theluthier didn’t encounter that problem.  In the meantime I’ve tested it with Blender 2.91 (the version used by Kent) as well: Same problem!
        @ger3d and @jordanofoz Did you have the same problem? In case you did, how could you solve it?
        #68709
        Ingmar Franz
          Ok, I could “solve” the problem by muting one of the last three “MixRGB” nodes (mode “Overlay” and “Multiply”; see magenta frame below):
          Muting one of the first two “MixRGB” nodes (mode “Mix”) doesn’t remove the magenta column shading.
          File with one column only is here.
          #68710
          Ingmar Franz
            I’m also facing the same problem when opening Kent’s @theluthier file realistic-eevee-environment_lesson_14_end.blend from the course resources:
            Again, muting one of the last three “MixRGB” nodes “solves” the problem:
            Maybe, it’s a memory issue or some other Blender settings have to be adjusted?
            #68711
              @duerer you probably need a more powerful GPU
              as Kent didn’t have this problem.
              #68712
              Ingmar Franz
                Please have a look at the error message in Blender’s “System Console” when unmuting one of the three “MixRGB” nodes in the magenta frame below:
                Note: This is just a small portion of the error message but as far as I can see, it’s a problem with the NVIDIA GPU. Complete error message is here.
                #68713
                Ingmar Franz
                  Thanks, @spikeyxxx! I’ve just had a look into the “System Console” myself and posted my finding above concerning the GPU but I didn’t think that my GPU (NVIDIA GeForce GTX 1060) was too weak. That’s really sad 😒.
                  #68714
                  Ingmar Franz
                    @spikeyxxx @theluthier @jlampel I’ve found a solution πŸ˜€πŸ˜€πŸ˜€!!!  Simply set the “Musgrave” texture node from 3D to 4D and you get the “pockmarks” (as Kent calls the little holes in the concrete) on your painted columns:
                    It came to my mind since there’s an info in the error message mentioned above in this thread: “Info: Successfully reset Musgrave Texture”. @spikeyxxx With your posting concerning “too many instructions” I first set it to 2 D which already solved the problem but didn’t create nice “pockmarks” in some areas (maybe rather a problem with the rotation values):
                    EDIT: “Musgrave” set to “3D” also works with type “Hetero Terrain” or “Hybrid Multifractal”:
                    The types “Multifractal”, “Ridged Multifractal” and the default type “fBM” don’t work on my computer.
                    #68715
                    Ingmar Franz
                      And that’s how the camera renders the scene now:
                      #68716
                        @duerer, after a good night’s sleep, I remember Simon Thommes saying that Mix Shaders are really expensive and although a Principled Shader looks like only one Node, it is already a  ‘mixing of Shaders’ under the hood (probably).
                        So let’s do all the masking before the Principled Shader like this:
                        (Sorry for not aligning my Noodles…)
                        Even my 10  year old Nvidia  GT630  can handle this and you don’t change the material this way :
                        As you can see, no error message.
                        #68717
                          @duerer I don’t understand those Error messages, I just look for something I can read and see: …too many instructions…(which probably is a RAM issue, not specifically a NVidia problem.)
                          I think it’s a problem with mixing Shaders (see also answer below), when a Principled Shader is like a Node Group that uses 5 Mix Shaders, then mixing two Principled Shaders means you’ve got 11 Mix Shaders!
                          #68718
                            Another small optimization would be:
                            Which in general is preferred, while you can change the Treshold with a Slider that you can control in a Node Group, while the Flag in the ColorRamp cannot….
                            #68719
                            Ingmar Franz
                              @spikeyxxx  You’re really masterly conducting the orchestra of nodes 🎼🎡πŸ₯πŸŽ·πŸŽΊπŸŽ»πŸ˜€!!!
                              #68720
                              Ingmar Franz
                                @spikeyxxx I think that’s what Kent @theluthier is referring to when he says (starting at 4:47 in this lesson) that modifying the existing color inputs (of the “Principled BSDF”) is a “more efficient setup for computation”. But he finds it “more complex for workflow” and that’s why he chooses to achieve the paint effect with a separate shader.
                                #68721
                                  Yes, when you have enough power (read GPU RAM), you can afford that πŸ˜‰
                                  It’s a bit like, when computers became faster and memory cheaper, a lot of people started writing longer and less efficient (slower) code…(who cares if a programm takes up 4GB on a hard drive, when a Terabyte costs next to nothing…)
                                  (Blender is somewhat of an exception…)
                                • The topic ‘“Industrial Environments with Eevee” Course: Columns Turning Magenta when Mixing in Second Principled BSDF’ is closed to new replies.
