[Creating snake scale] any way to work with Array modifier with Bezier curve without stretching the mesh?
Forum Archive [Creating snake scale] any way to work with Array modifier with Bezier curve without stretching the mesh?
Viewing 15 posts - 1 through 15 (of 24 total)
  • #14838
    talkingskunk
      Is there a way to keep the mesh from stretching like this when you go around a curve?
      #73330
        Hi talkingskunk, there is. Use Instancing in stead of a Curve Modifier. But there are some extra steps necessary:
        Create some scales:
        Make your Curve:
        Convert it to a Mesh and go into Edit Mode:
        Here you can already see two problems; the Vertex Normals are a mess and the distribution of the Vertices is uneven.
        Second part first: enable the LoopTools Addon and then W (when using RCS) or right click > LoopTools > Space:
        Now comes the trick; Extrude on the Z-axis (in my case):
        (This fixes the Vertex Normals, but we are not going to use that here, in stead we are using the created Faces.)
        Now back to Object Mode, Select your Scales, SHIFT Select your curve-mesh and CTRL+P > Set Parent to Object.
        Then go to Instancing and you can Instance on the Faces:
        #73331
          Sorry, I forgot, you can find that here:
          #73332
          talkingskunk
            Thank you. I’m having trouble how to make it go around the snake curves, as the the scale mesh will not turn with the curve?
            Still not certain re: relationship between normals of the faces with the mesh.
            #73333
            John Sanderson
              Alternatively, You could just use a plane with the array and curve modifier, have it parented to your scale and set up instances on it.  This preserves your curve so you can still edit it. Though spikey may know some reason this isn’t best practice?
              #73334
                @procyonlotor that sounds like a great idea, but I can’t get it to work..
                your method:
                vs mine:
                #73335
                John Sanderson
                  I don’t know why it did that.  It seems to work fine for me.
                  #73336
                    @procyonlotor I must have done something wrong then.
                    But will does your method still work when the curve is 3D like in talkingskunk”s snake?
                    Mine doesn’t, because you can’t extrude correctly anymore…
                    #73337
                      @talkingskunk I didn’t realize that the curve was so snakelike and not flat.
                      What you can do in your case, is to give the curve a Bevel and then convert it to a Mesh again and Instance a single scale to its Faces:
                      Of course first take care of the spacing in the Curve and make sure you have the correct resolution.
                      Important: if the orientation of the scales is wrong, first unparent the scale, the rotate it in Edit Mode (or Apply the Rotation) then Parent it again.
                      #73338
                      John Sanderson
                        it does.
                        #73339
                          @procyonlotor excellent! Sounds like the way to go then. Still being able to move the Curve is a great advatage.
                          I’d probably try something like this in Geometry Nodes, if I had to do it myself, but this is a great and very easy and accessible way to do it. Thanks for helping!
                          #73340
                          talkingskunk
                            Sorry guys. After trying array and curve modifier method to create scales, and after trying to draw the image texture in sculpting (both of which crashes my Blender),  I am trying UV editing with the image of scales I cropped from Google.
                            The issue: there are visible cuts in the model, as the image is not large enough to encompass the the entire unwrapped skin.
                            Question: How  would you go about this? Would you know how to make an array of the same image?
                            #73341
                            talkingskunk
                              #73342
                                You need to use a seamless (image) texture.
                                #73343
                                • The topic ‘[Creating snake scale] any way to work with Array modifier with Bezier curve without stretching the mesh?’ is closed to new replies.
