Collab 2020: Modeling Heavy Equipment (Backhoe)
Forum Archive Collab 2020: Modeling Heavy Equipment (Backhoe)
Viewing 15 posts - 1,231 through 1,245 (of 1,440 total)
  • #55007
      No way! How many files did you have to open till you found the poor pup?
      Honestly I’m impressed you found it. I’d already given up for the day 😅
      #55008
      Adrian Bellworthy
        I found it straight away.
        I added a cube, so I could select a material and using text search for ‘Steel_bolts’ it lists the linked files using that material and it had the chassis and the swing frame listed.
        So then went to the swing frame and removed the material.
        Must of become a stray when I moved the collection to the swing frame from the chassis.
        #55009
        Adrian Bellworthy
          Up here for dancing…..
          No that’s not right
          Down here for dancing, Up here for thinking.
          #55010
          Karen Trevino
            Hey Guys, I won’t make it to live stream. My mother had a stroke and is in the hospital. I will be with her as much as the hospital will allow. They aren’t letting me see her until tomorrow. Prayers appreciated
            #55011
            Shawn Blanch
              That’s terrible news @ketre. Prayers coming your way for sure!
              I don’t think the live stream is until Oct 20th so you may still be able to make it.
              #55012
              Ingmar Franz
                @ketre All the best wishes and prayers for your mother! I hope to see you here again soon with good news.
                #55013
                  Sorry to hear that @ketre . Best wishes from me as well. I’ll also be praying for your mother to get well.
                  #55014
                    @ketre I’m so sorry to hear the news about your mother. Absolutely sending prayers your way!
                    #55015
                    artifact
                      @ketre  Sad news about your mum. Will be praying for you all.
                      #55016
                        😳 …. 😅 I knew I picked the right MOLE for the job! One thing I did notice is that the assembly file was saved with 2.9. Shoudln’t be a big deal, just something I’ll make sure to mention in the next livestream. Either way, 2.83 or 2.9, it’s probably best if we all use the same version on this project (which is 2.9 now)
                        #55017
                        Adrian Bellworthy
                          ooops!!! Wasn’t thinking. Can you open in 2.83 then resave it??
                          #55018
                          Adrian Bellworthy
                            @ketre Sorry to hear the news about your mom, more prayers coming your way.
                            #55019
                            Adrian Bellworthy
                              Haven’t worked on the BIG DOG for a while, thought I would do a bit today.
                              Done the hand rails and mirrors, and started the interior.
                              @blanchsb you have set the standard for chairs, there is two in this dog. Not sure they will be as good as yours.
                              #55020
                                The warning makes me think it’s better not to. It would probably be fine but it’s surely not a good practice. Given the complexity I don’t want to risk a weird bug or hiccup in the scene/linking/data going back and forth.
                                Don’t worry though! Our DOG is officially a 2.9 project 👌👍
                                #55021
                                Jake Korosi
                                  Thinking about you and your mom, @ketre, hang in there.
                                • The topic ‘Collab 2020: Modeling Heavy Equipment (Backhoe)’ is closed to new replies.
