Collab 2020: Modeling Heavy Equipment (Backhoe)
Forum Archive Collab 2020: Modeling Heavy Equipment (Backhoe)
Viewing 15 posts - 556 through 570 (of 1,440 total)
  • #54332
    Ingmar Franz
      Oh no, it has two wheels and one axle more🤪.
      #54333
      Ingmar Franz
        Maybe this helps further:
        #54334
        Ingmar Franz
          @spikeyxxx Do you already know these Cat 434E front axle images?
          And the front differential:
          #54335
            Oh that’s great! Just when I was about to loose hope;) Thanks a lot @duerer !
            My biggest problem is not enough pictures.
            Although this one is a little different from the other picture, it still very helpful, because this show it from the other side and the close-up of the differential is also fantastic!
            Again, thank you!
            #54336
              Dude this helps a lot, thanks, I can see further details that before I could only guess…. aaaand that thing on the side is welded, that’s going to be a nightmare.
              #54337
              artifact
                @blanchsb
                I don’t think you’ll have to spread the loader arms out much further. I believe the problem lies with my initial extrusion to a detail I should have inset instead. I’ve highlighted the offending extrusion in red below at the 1st clash of the blends point.
                Insetting that detail plus narrowing the engine enclosure by a hair towards the back should sort that problem right out. Unfortunately I’m unable to work on the model until this weekend.
                @adrian2301  Thanks for the top view find. The taper @luthier had talked on the stream about was towards the front of the enclosure instead of towards the cab. Still, from the top view reference you found, it does seem that the part of the enclosure with that inset seems a bit narrower than the rest of the enclosure towards the back.
                #54338
                  Ahh I was wrong about the engine closure taper. It thins toward the cab . Fascinating. Never would have guessed that without the top-down view. Great find @adrian2301!
                  #54339
                  Adrian Bellworthy
                    Ok everyone, There is so much going on in the DOG Pound it’s getting a little unsafe around here, so I have managed to come up with some safety gear for everyone.
                    @theluthier @dostovel @blanchsb @jakeblended @shanr @ketre @spikeyxxx @ryzen7 @doulos4iesou @duerer @hellosudeepsingh @pfbourassa  @artifact
                    #54340
                      Cheers Adrian! I appreciate that!
                      (Nice ‘The invisible man’ reference,,,)
                      #54341
                      Shawn Blanch
                        Let’s keep him visible this way we don’t run over him LOL
                        #54342
                        Ingmar Franz
                          Maybe he (or she?) is a little bit shy😉?
                          #54343
                          Adrian Bellworthy
                            @duerer I saw a post earlier from you about the axle attaching to the chassis, unfortunately I read it on my phone and couldn’t reply, now I can’t seem to find it, can you give me some directions. Thanks.
                            #54344
                            Ingmar Franz
                              I’m just trying to align the rear axle with the chassis and the wheels, but I can only make it fit with the one or the other. The red element of the rear axle has to be attached with 4 bolts on both ends to the chassis where 4 bolt holes are needed:
                              I’ve created a smaller file with just the chassis, the rims/hubs and the rear axle here.
                              #54345
                              Ingmar Franz
                                I’ve updated it. You can find it below this post in the next reply section.
                                #54346
                                Adrian Bellworthy
                                  I can adjust the chassis as needed no problem, if its lower, higher, left or right I can adjust accordingly.If you sort your wheels out and best guess the location of the bolt positions in relation to the axle and I can then adjust the chassis to fit. Probably the best approach, as the chassis will hardly be visible when done, as long it doesn’t interfere else where not an issue. If we still have a problem then we can solve it then. The chassis has few images, only drawings that are not really clear, so it is more a task of align to other parts.
                                • The topic ‘Collab 2020: Modeling Heavy Equipment (Backhoe)’ is closed to new replies.
