BC1-1808 Homework, Andres
Forum Archive BC1-1808 Homework, Andres
Viewing 15 posts - 46 through 60 (of 66 total)
  • #39940
    Jake Korosi
      @aaltuvem I have headphones very similar to those.  Looks like an excellent job to me.  🙂
      Don’t feel bad about not being able to finish the pilder.  If you only need a couple more days, I think Kent will still accept it as long as you give him a heads-up.
      #39941
      Andres Altuve
        @nekronavt Hi Pavel, thanks! How can you tell the model got inverted normals?
        Thanks again!
        #39942
        Andres Altuve
          @jakeblended Hi Jake, I’m finishing the pilder! I did the headphones because I’m taking the class really serious and didn’t want to miss a homework..
          Thanks!
          #39943
          Julian B
            @aaltuvem
            This is the same cube but as you can see the right one is darker. That’s because its normals are flipped..
            To see in which direction the normals are showing you can press that little face button in edit mode under Mesh Display.
            To recalculate the normals select everything and press ctrl+N. You can also find that option in the T-toolbar under Shading/ UVs (in 2.79). Hope this helps. Btw very cool headphones! Good job! 🙂
            #39944
            Andres Altuve
              @bsdwerbeagentur Julian THANK YOU SO MUCH!! While making the pilder I got a lot of parts with the blueish color, and didn’t know the reason.. Now I know! Thanks for taking the time to explain me!
              #39945
              Julian B
                @aaltuvem You’re welcome, glad I could help. 🙂
                #39946
                silentheart00
                  Well, hey, you tried something challenging, and realized you couldn’t do it in the time limit, but now it’s the perfect project for next week!  Headphones look good, too.
                  #39947
                  Andres Altuve
                    @silentheart00  yeah I will keep working in it, I’ve been watching the modeling bootcamp and so far I got new knowledge that will help me to finish the pilder and on top of that Julian pointed out the normals issue.
                    #39948
                    silentheart00
                      @aaltuvem Awesome!  Put that new knowledge to use!
                      #39949
                      Aaron Rudderham
                        @aaltuvem I’m personally really looking forward to you finishing your initial project but I still think this looks good!
                        #39950
                        Andres Altuve
                          @thecabbagedetective  Thanks Aaron, I will finish it!
                          #39951
                          smurfmier1985
                            @aaltuvem Good idea to watch that course to up your knowledge! you’re improving fast you’ll get there, looks awesome so far. Keep up the good work! 😄👍🏻
                            #39952
                              @aaltuvem Aww I was a skosh disappointed to see headphones instead of a finished pilder…but let’s be honest, the headphones look pretty great on their own! Certainly deserving of an A 👍
                              You could finish the pilder for week 4 homework. I’m not the only one who wants to see that thing finished in full glory 🤩
                              #39953
                              Andres Altuve
                                @theluthier  Hi Kent, I was disappointed too but I didn’t have the time to work on the pilder, but you can be 100% sure that we will see the pilder before the class is over!
                                #39954
                                Andres Altuve
                                  Back to the Pilder :D, after watching more videos of the modeling bootcamp course I was able to identify a couple of errors I made, the biggest one was that the model of the pilder was high poly. By working with less polygons I have more control on how  the model flows and was able to build the middle part of the body. While being stuck in one part I built the engine.
                                  Now I can say I’m loving how is coming together. My plan for today after I finish work is to see more videos learn few tricks and keep building.
                                • The topic ‘BC1-1808 Homework, Andres’ is closed to new replies.
