Backhoe Contribution – adrian2301 – Chassis/Stabilizer/Fenders and the Engine. And the hydraulics for the swing frame.
Forum Archive Backhoe Contribution – adrian2301 – Chassis/Stabilizer/Fenders and the Engine. And the hydraulics for the swing frame.
Viewing 15 posts - 91 through 105 (of 135 total)
  • #56764
    Shawn Blanch
      Adrian Bellworthy
        I think your lines maybe slightly bigger than mine. The depth on the bevel for the curve I used is 0.5″, which is radius , as @blanchsb ‘s knowledge he shared. Cant remember what you used but I think adjusting the size of the joint, nut, union, not sure what it’s called, where yours meet mine might be the best option. I have increased the diameter of the centre as much as possible without increasing the size as a whole, but I could If needs be.
        Also I noticed the way your lines come from the loader arm where the turn towards the swing frame , the best location for each to avoid collisions would be the outer line to bottom connector, outer to inner line – bottom to top connector on each side. Does that make sense, not sure it does. The two outer lines to the two bottom hoses , next two lines from the outside to the next connector up, and so on. OK I’m sure you are smarter than me and know what your doing.
        #56766
        Jake Korosi
          @adrian2301 dude, that is outstanding!  Really, I can’t stop staring.  I wish I had access to the 3D model so I could have a look all the way around.
          I’ve been so nervous that this part might be left unfinished because of me, but those fears are completely gone now.  Thank you so much for taking up my slack!
          #56767
          Adrian Bellworthy
            Thanks @jakeblended , just continuing your good work.
            Some more shots for you.
            #56768
              I had to read this several times before I got it. Worth it 😆
              #56769
                I connected my lines easy enough:
                Our minds must have been telepathically linked because I took the exact approach you described! Also had to decrease the cables end control point to 0.9 radius. No one will ever know ..
                #56770
                Jake Korosi
                  Now just for the sake of theory – how would one go about rigging this for animation?  Of course the hoses are folded into those very large “wings” to allow the slide part of the swing frame to, well, slide from side-to-side across the back of the chassis.  I’m trying to figure out how a rigger might set up those hoses to deform properly and it’s just not coming to me.
                  Kent’s lines, leading out through the back of the swing frame, would be easy enough with like a simple deform modifier or a lattice I should think.  To save time, perhaps Wayne might decide to only rig the swinging capability of this part and not the lateral-sliding capability – after all, I’ve looked high and low and never once been able to find an actual video of the thing sliding.
                  #56771
                  Adrian Bellworthy
                    I’m sure the master animator @waylow will have a trick or two.
                    #56772
                    Adrian Bellworthy
                      Today’s progress:
                      The cable and assembly for the boom lock hook:
                      and the swing lock and holder:
                      #56773
                        Adrian you already won the Oscar for best motion picture, you got a #1 hit one the radio, you won gold on the Olympics and you married your high school sweetheart. I think you might be on the verge of discovering what consciousness is and curing cancer.
                        #56774
                        Jake Korosi
                          Masterful!
                          Looking through my reference photos, I’m pretty sure the only thing that’s left for this component is the grease fittings.
                          #56775
                          Wayne Dixon
                            Yeah, I know a few tricks, but they always depend on the circumstances.
                            If all those cables are curves (and not geo), it will be easier to rig the curves with hooks to some bones.
                            If it’s a cable or something that an animator won’t need to animate, you just need to figure out a way to make it behave w/o the animator needing to touch it.  So the solution could be really simple,…or super complicated haha.
                            #56776
                            Adrian Bellworthy
                              Drilled some holes and added the Zerk fittings, (grease fittings, to us earthlings).
                              And I think we are done with the swing frame assembly.
                              #56777
                              Adrian Bellworthy
                                @dostovel I haven’t got round to curing cancer yet but I have discovered the true meaning of life.
                                #56778
                                Ingmar Franz
                                  Looks really beautifull! I enjoy seeing all these details like the grease fittings 👍!
                                • The topic ‘Backhoe Contribution – adrian2301 – Chassis/Stabilizer/Fenders and the Engine. And the hydraulics for the swing frame.’ is closed to new replies.
