ATTENTION ALL PROBLEM-SOLVERS: How would you approach this scenario?
Forum Archive ATTENTION ALL PROBLEM-SOLVERS: How would you approach this scenario?
Viewing 10 posts - 16 through 25 (of 25 total)
  • #83698
      Another (easier) way could be:
      let the sun rotate ‘around the earth’ at a constant speed (two Keyframes, Linear Interpolation) and in the time that the sun rotates 360°, let 24 hours pass (also at a constant speed). That would still leave the issue, that a Sun Light in Blender doesn’t have a Location…but with a Bone (or an Empty), a Point At and a Copy Rotation Constraint, that could be solved relatively easy, I think…
      #83699
        Just tested it, with just the(not yet ‘aligned’ to the sun) hours:
        If you want to have a look at the file:
        https://drive.google.com/file/d/1xGIhErGq8MSZAUNRAcqAmtl9raEiKnRM/view?usp=sharing
        #83700
        Juan M Muñoz
          I looove how this forum collaboratively works towards finding solutions that seemed a maremagnum (an inmense chaos) to me just a few days ago. Thank you all, and @spikeyxxx, your solution is also possible! Instead of using textures, you can directly use the fonts from Blender, which is a practical solution to this problem.
          #83701
          anarchymedes
            I’d just replace the clock display with a text object: then it should be possible to use Blender Python API to update its value based on time or the current frame. This example of writing into a text object is pretty old (Blender 2.6) but who knows: it may still at least suggest the right direction; this one isn’t much newer (2.81) but shows a workaround for a possible issue with updating a text object on every frame; and that one (9 years old – which version was current then?) shows several short practical examples of showing the current frame, etc.
            The challenge would be to find a suitable font – but since the clock isn’t very close, it doesn’t have to be perfect.
            #83702
              Sounds like the setup worked and the clock changes the sun? Make a short screengrab video Juan, see how your setup is working since it’s a very unique thing you tackled.
              #83703
              Dwayne Savage
                @spikeyxxx and @Infoxicao just had a thought, another way to do it would to be to have a single texture with all the numbers 0 to 9 with exact number of pixels across for each number. Then use the UVWarp modifier with a UV Map just for the numbers on the clock or maybe a plane. Then use a driver for the x offset. Add a step modifier to the driver F-curve. How would one go about figuring out the math? Also I’m going to play with @spikeyxxx Goenodes setup. I probably should finish the particles course or assembly course first.
                #83704
                Dwayne Savage
                  @spikeyxxx method paired with this Digital Font I think is awesome. It also appears to be a pretty simple setup. I really need to learn more about goenodes. The only problem I see is it removes the leading 0 for first 9 minutes.
                  #83705
                    “The only problem I see is it removes the leading 0 for first 9 minutes.”
                    Yeah, I haven’t figured that out yet, but it shouldn’t be too hard to fix, I expect…Probably just using a Switch Node could do the trick..
                    #83706
                      …and @dillenbata3  @anarchymedes  and @Infoxicao about the posts before…it is amazing how many ways you can come up with when you start thinking about it, right.
                      #83707
                      Dwayne Savage
                        As usual you are spot on @spikeyxxx I didn’t even know about the switch node. It works great. I made it into a node group so I could apply it to the minutes as well. I’m Totally going to use this geonodes setup for my project.
                      • The topic ‘ATTENTION ALL PROBLEM-SOLVERS: How would you approach this scenario?’ is closed to new replies.
