@brzostek 🤔
Ok lets figure this out. Other people have already begun rendering, so the issue must be on your end. The Google Drive folder is currently mostly empty, syncing should be a breeze, so try this. Go to your Drive by hitting the Abstergo icon, and in “My Drive” where you see the folder you are linked with, hit “Remove” so it goes away fully for you. Then try adding it back and see if it now refreshes with everything how its supposed to be.
Fingers crossed 🤞🏼
Thanks for going through all the trouble, Piotr.
