Reply To: Grid Fill causing corner bulges even after subdivision – how to fix?
Forum Archive Grid Fill causing corner bulges even after subdivision – how to fix? Reply To: Grid Fill causing corner bulges even after subdivision – how to fix?
#96623
    That’s the tricky part, to get the shapes to merge seamlessly, even though they are different in their vertex count, now you have to make them similar and get the shape you want out of those vertices. That way make it one solid object that is optimized to get the desired shape out of just enough number f vertices. Because if it’s too many vertices then it’s so difficult to control.
