Reply To: Blanchsb’s Blender Nuggets
Forum Archive Blanchsb’s Blender Nuggets Reply To: Blanchsb’s Blender Nuggets
#61252
Ingmar Franz
    I’ve found a solution and it works essentially the way as you described it on your linked page above by using a “Face” as “Instancer” which has been duplicated with an “Array Modifier” (set to “Fit Curve”) and a “Curve Modifier”:
    And animated (Warning: Don’t get hypnotized 🤪😉):
    Play with the “Distance X” value in the “Instancing Plane’s” first “Array Modifier”:
    It’s important to check “Scale by Face Size” on the “Instancer” (the “Plane”) and to make use of “Curve Radius Smoothing”:
    File is here.
