Reply To: BC1-1808 Homework, Yukino Hatake
Forum Archive BC1-1808 Homework, Yukino Hatake Reply To: BC1-1808 Homework, Yukino Hatake
#39182
Aaron Rudderham
    @yukinoh1989 Another thing to keep in mind is the focal length of the camera. To edit this select the camera you wish to edit and then go to the camera symbol on the right side (may need to drag the panel out to see it):
    Now on the right you can see the “Focal Length” setting, and this basically determines how “zoomed in” your camera is (50 is the default). The lower the focal length, the wider the FOV and therefore making it seems zoomed out. Here it is at half the size:
    And here it is 50% larger than the default:
    This coupled with the tips @carrotnl and @smurfmier1985 gave should be very useful. For reference if I remember correctly, most real world cameras have a focal length of 50-60 but hey this is the CG world, we’re not bound by those laws!
