Reply To: BC1-1808 Homework, Yukino Hatake
Forum Archive BC1-1808 Homework, Yukino Hatake Reply To: BC1-1808 Homework, Yukino Hatake
#39177
Wilco Wilbrink
    @yukinoh1989 The effect you see in the camera is called clipping. You can set the clipping for the view and for the camera. For the view you can set it in the side bar – on the right of your 3dView. Under the header ‘view’ you can set the start and the end  clipping values.
    For the camera you can also set the clipping values.  When you select the camera you can set the clipping values in the camera settings in the properties bar on the right on your screen. See screenshot #2:
    As you can see there’s also a start clipping value. This means that if you com to close with your camera of view it will start clipping too.
    I hope this helps you a bit. 😉
