@yukinoh1989 Sort of, it has layers which function similarly but aren’t as deep as collections.
I presume you want it to turn from a triangle to a square? Simply select all of the verts you want to edit (as you have done), hit S to scale, then hit X the lock it to that axis, and then hit 0.
