Reply To: BC1-1808 Homework, Ken Claassen
Forum Archive BC1-1808 Homework, Ken Claassen Reply To: BC1-1808 Homework, Ken Claassen
#41080
silentheart00
    @cptken Great work!  You can use the decimate modifier to help cut down on the polycount.  I’d probably save what you have as a separate file, then apply the decimate modifier and go on your way.  That way you have your original copy to fall back on if things go terribly wrong.  Can’t help with the scars bit.  Experiment?
