* indicates required
Blender 5.0 Release – New Features & Download Guide
TL;DR: Blender 5.0 is on the horizon with some big quality-of-life upgrades, support for massive geometry, Grease Pencil motion blur, UI polish, and more. While many features are still under development, key highlights are already landing.
  • Beta begins: October 1, 2025
  • Release Candidate: November 1, 2025
  • Final release: November 18, 2025
This post will be continuously updated as new details emerge
A New Number Means a New Era? Right? 🤔
Every few years, Blender hits a milestone that feels more symbolic than numerical. Blender 5.0 is one of those, but not in a way that breaks everything you’re used to or a departure from your fundamental 3D skills.
At CG Cookie, we’ve been keeping a close eye on Blender 5.0’s development and plan to publish our classic “What’s New in Blender 5.0” video when the time comes.
The tricky thing is that at this point, there’s not much we know for sure, but we can guess at a few things!
My hope is that this post hits a bit differently than the SEO real estate grabbing blog posts we’ve already seen surface in search. While I do hope this page bubbles to the top of a Search for Blender 5.0, in the end, my first goal is to be a helpful place to keep a pulse on Blender 5.0’s development.
So let’s give it a shot! 👇
Keep tabs on it:
Follow and bookmark these links to keep a pulse on Blender 5.0 development.
Release Dates:
  • Beta – October 8th, 2025
  • Release Candidate – November 1, 2025
  • Release – November 18, 2025
Cool Highlights:
These are gleaned from the release notes link above. Bookmark it and keep a pulse on it yourself.
  • HUGE geometry now works (like, millions of vertices).
  • Grease Pencil gets motion blur!
  • Rigging gets 2 new cool features.
  • UI is getting even smoother.
  • Older big-endian system support has been dropped. While nobody was likely using them, it’s still cool to know Blender supported them all the way up to this point.
  • Major areas (Cycles, Geometry Nodes, Sculpt) are still in development, will update once more is released.
(By Daniel Bystedt
Big Files = No Problem-ish 🤞
If you’ve ever tried importing a highly detailed 3D scan or massive geometry set, you know the pain. Blender 5.0 introduces support for massive buffers in .blend files, making it possible (IF you still have the crazy machine for it) to interact with the files.
⚠️ Note: Files saved in 5.0 may not open in versions before 4.5.
Why it matters:
Artists working with dense models, simulations, or game assets can breathe easier. Blender is catching up to your creativity.
Link to Core Release Notes
UI Tweaks:
UI updates may not grab headlines, but they shape how you feel working in Blender every day. Version 5.0 continues the cleanup with:
  • Better drag-and-drop (especially for shape keys)
  • Improved outliner behavior and feedback
  • Unified widget styles across the interface
  • More polished menus and layout adjustments
Why it matters:
These subtle refinements help reduce friction, improve discoverability, and make Blender feel more approachable, especially for new learners or those teaching it. Think of it as a fresh coat of paint on your home.
Link to UI release notes
Grease Pencil Gets Motion Blur
You can now add motion blur to Grease Pencil renders, an exciting development for hybrid 2D/3D animation. Grease Pencil is a feature that allows users to draw 2D lines and strokes directly in a 3D scene.
🎞️ Render → Enable “Motion Blur” → Adjust Steps
It doesn’t yet appear in the viewport or compositor, but it’s a strong sign that GP is becoming even more production-ready.
Why it matters:
2D animators and illustrators using Blender will find that their output feels more fluid and cinematic.
Link to Grease Pencil Notes
Rigging Improvements!
This release has seen some welcomed improvements in the rigging domain.  Here’s some of the highlights.
A small change to the weight painting algorithm makes it so much easier to paint weights down to zero.  So now you won’t need to spam the button to remove those rouge weights.
With the new options for bone widget transform overrides, it’s possible to have 1 bone display at a different location and also pivot from that new location.  This is a huge!
The new Geometry Attribute Constraint is a way that objects and bones can interact with a Vector, Quaternion, or Matrix attributes from geometry objects. This opens up a range of flexible and robust workflows without a bunch of workarounds.  Like for example – Bones directly interacting with data that is generated by Geometry Nodes.
It will be interesting to see how people use this new constraint is innovative and clever ways.
No More Mouse Fights with the Video Sequencer!
A small but mighty tweak: when you press Shift + A to add a strip, it now appears exactly where your mouse is. No more accidental misplacement.
Why it matters:
If you’re editing in Blender, this is one less thing to fight with. More flow, less fuss.
Link to Sequencer Notes
What’s still cooking in development, and our guesses?
Many sections of the Blender 5.0 release notes, like Cycles, Geometry Nodes, Sculpting, Rigging, and Compositing, are still blank or under construction. That’s pretty typical at this stage.
One exciting bit we’ve heard: UV Sync Selection is finally getting fixed or improved. This has been a long-standing request (just ask Jonathan Lampel and others at BCON LA!).
On the modeling side, it looks like more operators will support Edit Mode symmetry, which has been only partially implemented and not very practical until now.
There’s also some speculation around animation layers, could this be the release where they finally land? Time will tell!
Since 5.0 is a major version bump, it’s also the window for breaking changes. That likely means some add-ons will need updates and might not work immediately.
We’ll keep listening and updating this post as more details come out.
Thanks for reading, and now, a quick word from our sponsor. 🙂
Frequently Asked Questions
When is Blender 5.0 coming out?
Blender 5.0 is scheduled to release on November 11, 2025. Beta begins on October 1, with a release candidate expected by November 5.
Will Blender 5.0 break my existing projects?
Mostly no, but some older files may need updates. Files saved in Blender 5.0 might not open in older versions.
Will Blender 5.0 break my add-ons?
Probably yes.  Major version bumps  like 4.5 to 5.0 are the time when breaking changes to the api are introduced. While some add-ons won’t be affected, other will need to be updated by their authors.
What are the biggest new features in Blender 5.0?
Support for massive geometry, UI improvements, motion blur in Grease Pencil, and enhancements to modeling tools are among the highlights.
Wanna Prep?
If you want to hit the ground running when Blender 5.0 lands, now’s the perfect time to build your foundation. Our CORE program is a 9-course learning path designed to teach you the skills that matter, including modeling, lighting, animation, and more, without getting lost in the noise of constant version updates.
Check out the CORE Series on CG Cookie and or Superhive
