Sakhia Kwemo
Forum Replies Created
  • in reply to: My weight paint is not working for some reason #90719
    Sakhia Kwemo
      hey Omar and Martin thank you so much for the feedback. I was able to fix my first problem. I was using a displacement modifier which was only being seen in the Cycles View. I changed my method and instead created a large plane which i subdivided a lot, and then i added a noise transformer, which i scaled to make it look like mountains, thank you so much for that
      in reply to: My weight paint is not working for some reason #90716
      Sakhia Kwemo
        Thank you Dwayne, Martin and Omar for the quick responses, I changed the viewing mode from rendering to solid, and I went into edit mode to check out the geometry of the landscape, that being said for some reason I also changed the brush to “draw” instead of “add”, but for some reason I am still not able to paint.
        https://www.youtube.com/watch?v=RX9eSzVjcaU&ab_channel=DJKwemo
