X-Ray in viewport even when X-Ray is off. . .
Forum Archive X-Ray in viewport even when X-Ray is off. . .
Viewing 12 posts - 1 through 12 (of 12 total)
  • #16597
    Austin Dunham
      Hi All,
         I’m having a problem I only noticed with 3.6, though I’m not certain if my issue is with that or something I’ve inadvertently toggled.  I think it’s something I’ve toggles since it doesn’t happen with a new file, but I can’t find it.
         I have something very close to x-ray mode when I’m in edit mode, even with x-ray turned off.  It’s not the clipping distance, but it’s a bit inconvenient.
      Here is x-ray off:
      Here is x-ray on:
      You can see a few more edges, and you get a more transparent gray, but even with x-ray off you can see through the object, which I’d like to avoid.
      I’m not sure what I’ve switched on to give me the always on transparency.
      #80153
        Could you upload that file please? It’s time to do some science.
        #80154
        Austin Dunham
          This should be the file: Hanger Boom.
          #80155
          Austin Dunham
            Yeah,
               I think it was my messed up scale.
               I had to take the clipping distance way, way down.
               When I scaled things up to the “proper” scale, I got all sorts of artifacts until I increased the clipping distance again.
            #80156
            Austin Dunham
              To be clear, my object was way smaller than it should’ve been.  I’m not sure when I did that, but the manta ray was shrunk down like it was going to do a Fantastic Voyage through a person’s veins.
              #80157
                Hi Wardred,
                I can’t believe I’m saying this to an experienced user like you, but did you check your drivers?
                this is 3.6 (no changes made to size or scale or anything):
                #80158
                Austin Dunham
                  Hey Spikey!  I’m on a Mac, so there’s not too much to do on the drivers front.  I am using 3.6.
                  If you look at the object it’s rather small.  0.05929 m by 0.002143 M by 0.012373 m.
                  To get things to work I had changed my clipping distance fairly severely.  I’d also, I think, made the bevel and merge distances really small too.
                  That should’ve been a clue to me that my scale was really small.
                  That same object at the proper scale is well over a meter long.  (It’s even longer now, I’m trying to make it a hydraulic boom for the door, so it’s tricky to say just how long it is when compared to what I sent.)
                  Correcting the scale and clipping distance, on an M1 Mac, did the trick.
                  #80159
                  Austin Dunham
                    Ironically, when I enlarged everything I had a different clipping issue in that the wings and everything started clipping all over the place.  Having a larger ship with a really small clipping distance didn’t play well with the M1 Mac.  Increasing the clipping distance again corrected that.  It didn’t impact orthographic view, but perspective view was really unhappy.
                    #80160
                    Austin Dunham
                      It looked like this:
                      #80161
                        It’s not so much the Clipping values per se, but the fact that the End Clipping is about 10 000 000 times the Start Clipping.
                        This is because a ‘float’ only has a certain ‘size’ and if you divide a meter in 1000 pieces, you can see the difference between 3 and 4 mm, but if you divide a kilometer in 1000 pieces, 3 and 279 mm are indistinguishable….
                        I hope this makes some sense at least…It’s ther middle of the night here and I am having problems explaining things clearly 😉
                        #80162
                        Austin Dunham
                          Hi Spikey,
                             It definitely felt like a variable overflow, and having too big of a range definitely makes sense.
                             I don’t know if this is true of graphics drivers, but I can definitely see an issue where some systems may have more bits for their float that an issue could happen on one system that doesn’t happen on another.
                             I don’t know why I had the scale of my object so far off, but it’s all corrected now.
                             Thank you!
                          #80163
                            Noted in my brain, the scale of the mesh in Blender can mess up tits transparency in the viewport. Blender is a weird box of unexpected surprised.
                          • The topic ‘X-Ray in viewport even when X-Ray is off. . .’ is closed to new replies.
