Yes, I would use the same field of view in any game engine, though be aware that some apps use a horizontal field of view number while others use vertical. I don’t know which one Unreal uses offhand, but here’s a calculator in case you need to convert: Horizontal/Vertical FOV Calculator (themetalmuncher.github.io)
Author
The topic ‘Would you also use 49 as the field of view in unreal engine?’ is closed to new replies.
