WIP – Epic Pumpkin Contest ..well…sort of WIP…
Forum Archive WIP – Epic Pumpkin Contest ..well…sort of WIP…
  • #10117
    smadoc
      Not exactly a WIP as I’m done with it being as the contest is closing soon. But thought I’d share some of the images I did during the whole process. Maybe for the next contest, if I have an idea, I’ll start a thread before hand haha.
      As I mentioned in my entry, I got the idea for my scene from the wording in the contest it’s self “…come up with a presentation of your pumpkin that would frighten a Rancor.” As usual, I had more ideas for the scene than I had time for. Would have been awesome to animate it more (I did a small..and I mean less than 200×200 render of the door coming down just to see it, but mostly to get the motion blur for the door, and maybe crack the pumpkin. My hardware is old so rendering took forever, 7 hours for the final scene, which I’ll post in a reply along with 1 or two of my early renders of the actual scene.
      I started with a drawing on my phone (the built in S-pen is handy for such things). Then did a screenhshot of it, opened it in inkscape, or gimp, can’t remember which, and after tracing the path, saved it as an SVG.
      Then I imported it into blender, converted it to a mesh and deleted extra edges before extruding and using it with the boolean modifier to “carve” out the face. Did this for the three pumpkins I did.
      Also, this first sketch I did I actually made a real jack-o-lantern from it. I’ll grab an image of that tomorrow and post it as a separate reply though.
      #43916
      smadoc
        Here are a few shots of the early renders of the scene.
        #43917
        smadoc
          And the “final” image. I’m sure at some point I may revisit it. Clean it up a bit, MAYBE even make a 360 VR image/video out of it, we’ll see. 🙂
          Wish I had more time to work on the rocks, and the floor, but it is what it is. In the long run I did learn some new things. I had never really used sculpting before (used it for the walls of the “pit”.) I also learned a bit more on how to group nodes, and manage their inputs/outputs and to how to put connector nodes, if thats what they’re called, to group similar inputs to different shaders and filters. Comes in handy sort of for cleaning up node spaghetti haha. 🙂
        • The topic ‘WIP – Epic Pumpkin Contest ..well…sort of WIP…’ is closed to new replies.
