Why my cube doesnt "jump" while rotating around pivot – 3d center? It does while i rotate, but key frames provide only usu…
Forum Archive Why my cube doesnt "jump" while rotating around pivot – 3d center? It does while i rotate, but key frames provide only usu…
  • #5563
    kameraman
      Why my cube doesnt “jump” while rotating around pivot – 3d center? It does while i rotate, but key frames provide only usual rotation of cube. What do i do wrong? What did i miss? Thanx!
      #24029
      Chris McFall
        I don’t know I would assume you used copy rotation or similar rather than child of (or perhaps unticked some options) If your still having problems can you send me the blend file? (sorry for slow reply ive been away)
        #24030
        kameraman
          thanks for reply! )
        • The topic ‘Why my cube doesnt "jump" while rotating around pivot – 3d center? It does while i rotate, but key frames provide only usu…’ is closed to new replies.
