Why is my Normal looking weird
Forum Archive Why is my Normal looking weird
  • #12303
    the3dbanana
      i watched this tutorial and decided to line the edges with bolts. i did this with 2 materials but the distortions happended when i subdivided the cube 10 times. how do i fix this distortion? please help
      #58627
      Chunck Trafagander
        Hey there! So did you unwrap first and then subdivide again? As well, you say you did this with two materials, could you tell me a little bit more about that? 🙂
        #58628
        the3dbanana
          never mind, i fixed the problem. i had a bevel modifier going and i forgot to make it only effect specific edges. when i changed that back, it was instantly resolved
          #58629
          Chunck Trafagander
            Ha, the modifiers always get me too. It gets tough when there’s so many mods on an object! Glad it was an easy fix. 🙂
            #58630
            the3dbanana
              so my process was i first decided to make only the edges of the cube bolts. i then subdivided it 10 times so i could a aply a different material to the edges so the edges would have the bolts but not the center. just to make sure nothing changed in the UVs, i reunwraped it. next i copied the material that had the bolt Normal applied and on the second material, deleted the normal and assigned it to the center.  and in the end i had this
              #58631
              Chunck Trafagander
                That’s looking real cool! It’s definitely a well secured box, with as many bolts as that has. 😀
                #58632
                the3dbanana
                  thanks! it was just a basic 2 min project that i did to practice my Normal maps
                • The topic ‘Why is my Normal looking weird’ is closed to new replies.
