Why does my subdivision modifier appear to ignore some creases?
Forum Archive Why does my subdivision modifier appear to ignore some creases?
  • #13309
    deadpunkdave
      I am applying the subdivision modifier to my low poly mesh, ready for baking. With every edge set to mean crease 1, I end up with this:
      Almost everywhere the creasing is working properly, but the subdiv is clearly ignoring it for the largest front face and in a few other places.
      Wherever this occurs, it looks as though the subdiv is resulting in 2 faces on top of each other with conflicting normals, as turning on face orientation looks like this:
      Any ideas as to what could be causing this?
      #62363
      deadpunkdave
        After thinking some more I realised that subdiv really wants to work with quads so I have started to cut up the n-gons around the problem areas and this is fixing the problem. I’m adding a few vertices to the model but I think I will live with that.
        #62364
        Jonathan Lampel
          That would do it! Tris or quads help hold the perimeter in place.
          #62365
          deadpunkdave
            Oh you’ve made me realise, I removed the triangulation modifier when I added the subdiv, if I had just applied it instead I would never have had this problem, and I wouldn’t have needed to add any vertices. Well I feel silly but at least I’ll know for the future, thanks Jonathan.
          • The topic ‘Why does my subdivision modifier appear to ignore some creases?’ is closed to new replies.
