why does array modifier work with object offset?
Forum Archive why does array modifier work with object offset?
  • #11409
    shan jay
      when I click on the eyedropper and click on another mesh in order to make my array go in a circle but the array goes crazy. is this an error? is there any another way to do this?
      #53307
        Use CTRL+A > Apply All Transforms (on both meshes). If there still is some offset left when the ‘other mesh’ is not rotated, make sure that Object Offset is the only thing checked (so no Relative or Constant Offset!).
        #53308
        shan jay
          it doesn’t work
          #53309
          shan jay
            is there any other way?
            #53310
              Could you provide us with a screenshot?
              #53311
              shan jay
                Here’s two a before and after
                #53312
                shan jay
                  it hasn’t changed at all
                  #53313
                    Uncheck the Relative Offset and put an object in the Object Offset field (it’s still empty in the screenshots).
                    Then you should see only one of the arrayed objects, because all 14 of them are at the same place, but when you then rotate the ‘Offset Object’ the array should go round.
                  • The topic ‘why does array modifier work with object offset?’ is closed to new replies.
