Why did we use the compositor for denoising?
Forum Archive Why did we use the compositor for denoising?
Viewing 10 posts - 1 through 10 (of 10 total)
  • #12781
    amannin
      Why did we use the compositor for denoising instead of any of the render denoisers? Is one better or faster than the other? Non-destructive? Personal preference?
      #60452
      Jonathan Lampel
        Open Image Denoise gives the highest quality of the denoisers, but at the time of recording it was only available as a node and not listed in the render properties. Feel free to check that on instead!
        #60453
        amannin
          What about when compared with Optix, for those of us with newer nVidia GPUs? Also, what about animations, is one better than the other, or what’s the best method for that?
          #60454
          Jonathan Lampel
            Optix is way faster and looks really good too – I think it’s a bit too dark at lower sample counts but the speed can certainly make up for that. At the moment none of the denoisers are temporally stable, so just go with whatever either looks best or is fastest depending on what you need.
            #60455
            Nathi Tappan
              I’m not entirely sure, but I believe for animation we can check the “Experimental” in the GPU setting for cycles, then click this button under the Advanced tab.
              It randomizes the noise, which makes it less noticeable over 24fps or more.
              But again, I’m not entirely sure this is correct. @spikeyxxx could probably let us know 🙂
              #60456
              Nathi Tappan
                Oops… forgot to attach the screenshot.
                #60457
                  Hi Nathalia @nathitappan ,
                  That is absolutely correct!
                  That clock icon changes the distribution of the Samples per frame, thus varying the noise pattern (a bit like how film grain changes per frame).
                  (It does not remove any noise, it is not a denoiser.)
                  #60458
                    I thought that clock was removed a couple of Blender versions ago. It was either there the whole time or it was put back in again. Cool.
                    #60459
                      I don’t think they ever removed it, Omar…they just hid it away under Advanced.
                      #60460
                      Nathi Tappan
                        Cool! I’m glad I had that right, I wasn’t sure if it was like a placebo effect to me, cause while not denoising it does feel like it make the noise on my animations a tad better (in fact, some noise is always wanted right? I add noise to my compositions in after effects pretty much on auto pilot at this point lol).
                      • The topic ‘Why did we use the compositor for denoising?’ is closed to new replies.
