Why aren't my meshes updated after applying the MeshDeform modifier? You said I must press TAB after it's binded, but noth…
Forum Archive Why aren't my meshes updated after applying the MeshDeform modifier? You said I must press TAB after it's binded, but noth…
  • #5334
    Camilo Montolio
      Why aren’t my meshes updated after applying the MeshDeform modifier? You said I must press TAB after it’s binded, but nothing happens. I’m using v2.78.
      #23712
      Alexandre Flórido
        I am having the same problem. My mesh is behaving like this example (https://blender.stackexchange.com/questions/61734/mesh-deform-modifier-not-working). The mesh is not stretching to the fit L.eye.meshdef. Need help ,please.
        #23713
        philichez
          I figured it out. Just activate the mesh deform modifiers before adding the lattice modifier to the meshdef
          #23714
          tonyhan55
            yep i cant seem to figure it out
            #23715
            Paul Briggs
              Or just don’t deform the lattice into a rectangle until you’re finished adding the meshdeforms. So, you’ll have to do it a little backwards from the video.
              #23716
              Oka Ong
                just reverse the steps, and it works.
                Means, don’t apply lattice first. Apply MeshDeform modifier first.
                #23717
                bluereaper
                  Thank you for the post helped !! 🙂
                  #23718
                  gimmi45
                    Thank you it helped me as well
                    #23719
                    David Soares
                      Correct, to date this is still how it does work.
                      First the MeshDeform modifiers,
                      thx.
                    • The topic ‘Why aren't my meshes updated after applying the MeshDeform modifier? You said I must press TAB after it's binded, but noth…’ is closed to new replies.
