Where is the link to the counter add-on?
Forum Archive Where is the link to the counter add-on?
  • #11121
    Cletus Kasenga
      Counter add-on
      #52368
      Phil Osterbauer
        I’m pretty sure this is it: https://leomoon.com/downloads/plugins/leomoon-textcounter/
        You could also go under Output property and under Metadata turn on frames and turn up the text size so it’s clear on screen.
        #52369
        Wayne Dixon
          Hi Cletus, just use the meta data like @phoenix4690 mentioned.
          That way you don’t need to make sure the script is running (plus I don’t think the text counter works in 2.8x)
          Make sure you check “Burn Into Image” and increase the font size to something readable.  (it’s pretty small for large renders)
        • The topic ‘Where is the link to the counter add-on?’ is closed to new replies.
