When you went back into Edit Mode to delete the cube above the uv sphere how did you instantly select the entire cube? All…
Forum Archive When you went back into Edit Mode to delete the cube above the uv sphere how did you instantly select the entire cube? All…
  • #4048
    Erik Jorrick
      When you went back into Edit Mode to delete the cube above the uv sphere how did you instantly select the entire cube? All I have is a vertex selected when I do that.
      #21963
      Erik Jorrick
        You never unselected the cube. It remained wholly selected throughout.
      • The topic ‘When you went back into Edit Mode to delete the cube above the uv sphere how did you instantly select the entire cube? All…’ is closed to new replies.
