when you put out in the parameter what does it mean?
Forum Archive when you put out in the parameter what does it mean?
  • #7997
    i am guessing this would pass the  reference of the object and we are only saying that the function will return an instance of the object as a result… but i am rusty on c#, i don’t actually remember this syntax
    #27988
    Jonathan Gonzalez
      Yes that’s basically it. We’re passing the reference. If I remember correctly “out” is typically used when you want to pass multiple values from a method instead of just one.
    • The topic ‘when you put out in the parameter what does it mean?’ is closed to new replies.
