when to use texture paint/vertex paint/shader editor?
Forum Archive when to use texture paint/vertex paint/shader editor?
  • #12535
    man5678
      so if i come across a problem where i can use a material node set up instead of vertex paint or texture paint why should i use a material node setup? for example ive seen people use material node setups instead of texture paint to create an apple material, where as ive seen some people use texture paint, which option would be the best for the scenario?
      #59471
      Jonathan Lampel
        They can be two ways of achieving the same thing, and you won’t find it intuitively clear when you should pick one over the other until you learn to do both. Texture painting is great for total artistic freedom but can be limited by the texture resolution and UV unwrapping, while the shader editor procedural textures are great for repeating patterns that don’t depend on UV’s. I’d say start with texture painting if you’re unsure and go from there.
      • The topic ‘when to use texture paint/vertex paint/shader editor?’ is closed to new replies.
